Hi experts
Looking for some help with a treadmill power supply. A few weeks ago my treadmill stopped working after I noticed a flash coming from power board. It still is turning on and stopping after 7 seconds which to me meant magnetic optical sensor wasn't working. Removed cover and inspected sensor , the cable was chipped and shorted with treadmill body. Ordered a new sensor cable from eBay. Replaced the sensor and no change.. treadmill still stopping after 7 sec. Had to check further in the board and appears there's a diode connected to the sensor input pin. It's a glass diode with A blue stripe on it. It's reading 34 both ways on a digital multimeter set to diode test. My guess is it's a 5v zener diode but I am not sure. Want to order a replacement but just want to be sure before ordering.. I have two similar diodes in the circuit with variable readings in fwd and reverse mode without any labels. Is there a way I can be sure what exactly I need to order or ideally a way around to fix it. Attached is a pic.. the diode next to a white 2 pin input is the probable suspect.. thanks in advance
