Expresscard 34mm to PCI x1 to PCI x16
ArakelTheDragon
Joined Nov 18, 2016
1,366
Hi guys,
I have an external video card riser, I want to connect it to the expresscard slot, because I don't want to keep the laptop open or have to drill the case. I see these expresscards to USB 3.0, is it possible to remove the external PCI x1 adapter and connect the USB cable to the expresscard USB 3.0? I tried to find an expresscard to PCI x1, but they are discontinued or extremely expensive as the manufacturer does not wants you to be able to boost your laptop performance.
I put dropbox links as I can't upload the files for some reason:
https://www.dropbox.com/s/dqoionvmll8ng9r/IMG_20191107_103126.jpg?dl=0https://www.dropbox.com/s/mn7idnc97isrwqk/IMG_20191107_102722.jpg?dl=0https://www.dropbox.com/s/rjnm6g39dv8kg7h/Files_Scratched.PNG?dl=0
