Exploring programming a XY6020L power supply via modbus
Curt Carpenter
Joined Jun 25, 2018
44
I have purchased a Chinese XY6020L variable buck power supply from Ali Express. It has a serial Modbus interface-- but no information that I can find anywhere as to how to program for it. No idea, for example, what baud rate the supply uses with the serial modbus protocol.
Being adventurous, I want to figure out how to program this supply and control it from my PC. What I'm looking for here is some advice on how to get started. I have the supply connected to my PC with a suitable interface and can send characters from PC to supply -- but no idea how to begin actually probing to get some modbus responses back from the supply. Any ideas on how to proceed would be welcome!
Curt Carpenter
Joined Jun 25, 2018
44
You need to learn about MODBUS, but not from youtube.
Thanks. I've studied the modbus protocol spec but didn't see anything there that I thought would help me "ping" my device somehow to at least establish a working connection. The protocol itself seems pretty straight forward. The only thing I know about the supply's modbus interface is that it has default address 1 and (probably) default baud rate 115200.
g-radmac
Joined Nov 13, 2023
Hi there,
looking for the same thing here, were you able to make it work?
Actually did some experiments
- port settings: 115200 baud/s
- last 2 bytes are CRC
- 1st byte is slave address - in my case is 0x01
- 2nd byte is function
more info about modbus and functions for example here https://www.simplymodbus.ca/FAQ.htm
analog output holding registers
register 0x0000 = set voltage - read/write
register 0x0001 = max current (i think)
register 0x0002 = voltage applied on the output (when on) - i think this one is read only
register 0x0012 = turn on/off the output, aka apply/provide set voltage to output
functions
0x03 - read analog output holding registers
0x06 - set analog output holding registers
read registers command example
01 03 00 00 00 14 45 C5
ID 0x01
function read analog output holding registers - 0x03
starting register address - 0x0000
number of registers to read - 0x0014 (20)
CRC - 45 C5
response
01 03 28 01 F4 01 90 01 F4 00 00 00 00 0B DC 00 00 00 00 00 00 00 00 00 00 00 32 00 1E 01 32 22 B8 00 00 00 00 00 00 00 01 00 00 B7 D1
ID 0x01
length of the response data - 0x28
Register 0 Data - 0x01F4 (500) = 5.00V
Register 1 Data - 0x0190 (400) = 4.00A
Register 2 Data - 0x01F4 (500) = 5.00V (indicating the output is on so set voltage is actually on the output)
Register 12 Data - 0x0001 (1) - set voltage to output
other example commands
turn on
- 01 06 00 12 00 01 E8 0F
turn off - 01 06 00 12 00 00 29 CF
set 5V - 01 06 00 00 01 F4 89 DD
set 15V - 01 06 00 00 05 DC 8B 03
I am sure with this you can figure out the rest of the registers that are used and how they function.
functions
ID 0x01
CRC - 45 C5
response
ID 0x01
turn on
Perfect, thanks for the information. I'll order one to test on my solar energy project MODBUS interface as a utility charger.
Why do they try to make it so hard to find simple information on a product from China?
Curt Carpenter
Joined Jun 25, 2018
44
Thanks for the information. I've been working another project and had to set the PS aside, but will get back to it in a day or two and let you know if I have any success. Thanks again for the starting point!
hardym2
Joined Dec 26, 2023
Thanks for all your analysis. I am new to modbus, and new to the XY6020L interface.
On the xy6020l product description, there is an small interface for the available wifi module, and the interface can be used for serial to RS-485 (I've not seen an adapter part available).
There are also 4 holes for serial, that is referred to as modbus.
Are these the same interface? that is, do we think that the wifi is communicating modbus data?
Do we know the pinout for the 4 hole modbus interface?
Is the modbus serial interface really +/- 5 volts?
Is the modbus interface on all the time, or does it have to be enabled via software configuration?
Arduino can do modbus protocol, but probably not the -5v. Is there a simple circuit that can be used to interface the xy6020L modbus into an Arduino?
On the example run, register 6 was 0x0DBC. That is 3036. Do we think that the input voltage was 30.36 volts during this run, so register 6 is the input voltage.
(fyi, my purpose with this is a small solar charge controller, to optimize power output from a solar panel to a battery, need to make realtime output current adjustments and monitor input voltage realtime. A solar power optimizer + voltage booster)
hardym2
Joined Dec 26, 2023
I have a couple of answers
Modbus is just a protocol that can ride on many hardware protocols, like RS-232. I suppose that the interface on the XY6020L board is TTL, RS-232, and the framing protocol is Modbus.
The XY6020L Wifi adapter is a XY-WFPOW. This appears to be a modbus-enabled implementation to their custom App.
https://www.aliexpress.us/item/3256802230942869.html?gatewayAdapt=glo2usa4itemAdapt
https://templates.blakadder.com/sinilink_XY-WFPOW.html
The app for the Wifi adapter is (apparently) only available for android,
and is listed in the comments here:
discord
Joined Jan 7, 2024
@Curt Carpenter and others. Pardon my ignorance.
I'm interested in the XY6020L, but am having trouble understanding what it is. Is the device a "buck / boost" power supply? My confusion is caused by the marketing of the device. In some posts I see it mention buck / boost converter.
In other posts I see it labeled as a buck converter.
For example, can I both step and step down from an input source?
Can I step up 13.5 V to say 15V ?
Similarly can I step down 15V to say 13.5V ?
Hockey
Joined Jan 2, 2024
This is a buck converter. It can only step down voltage.
The specs on Aliexpress indicate:
Maximum output voltage: (input voltage+1.1) - 2
So 15V could be stepped down to 14.1V (or anything below that)
If you wanted 15V output, you would need to input at least 15.9V... however I would suggest providing some extra, say 17V or more. In my limited experience, it is not advisable to operate right on the limit of the specs.
discord
Joined Jan 7, 2024
Yeah it wasn't clear to me as some sellers mark this as a "Buck Boost Converter" : https://www.aliexpress.us/item/3256...3a433f-6&utparam-url=scene:search|query_from:
60V 1200W 20A DC Buck Boost Converter CC CV Step-Down Module LCD Adjustable Regulated Stabilized Voltage Power Supply
Thanks for clarifying.
28,332
Often the sellers are clueless as to what the original description means. Or maybe this description was created by an AI robot that inserted "Buck Boost" because it was a close match.
I recall a listing for a "100 watt amplifier" that was actually 100 milliwatts. rated. Just a case of the writer not recognizing the "milli" part of the word. It seems that not everything stated in on-line advertising is correct.
Thanks to g-radmac for his discovery of the UART protocol.
With help of his information I created the Arduino library to control the xy6020l dcdc via a cheap Arduino pro micro clone from china.
The meaning of the transfered holding registers are explained in the header file: xy6020l.h
With a control & transmit rate of around 200 ms it works fine. Sometime the xy6020l ignores set requests and no answer on bus is provided.
Publishing the library is not finished yet, so you will not see it on Arduino IDE library manager.
GitHubs repo:
-> xy6020l
stealth8020
Joined Mar 29, 2024
GitHubs repo:
-> xy6020l
Hello Jens, I have tried out your library but it seems not working with ESP boards. I have reused your register informations and have written new web based GUI for Wemos D1 Pro board. During development I found a very good documentation about Modbus registers of XY6020 here: https://github.com/creepystefan/esphome-XY6020/blob/main/doc/XY6020L-Modbus-Interface.pdf
If somebody is interested in xy6020 controlling web app for esp8266 here is my github repository: https://github.com/stealth20/xy6020_wifi_ctlr
Curt Carpenter
Joined Jun 25, 2018
44
Thanks to everyone for the good information. I've finally finished my power supply project with your help, using a WEMOS D1 ESP2866 board programmed (with Arduino) to support a UDP connection to my PC and impliment a 20-key remote control interface. A screen shot of my PC interface (written in free pascal+lazarus) is attached.
Depending on operating mode, the power supply itself can take a very long time to settle after a control change. I've seen over 15 seconds when operating current limited with a change in output voltage, with 4 seconds not unusual. There may be a way to shorten this as I learn more about the use of the various controls. Noise performance over my range of 0 - 35V is surprisingly good although I've not pushed more than 150mA out of the supply so far.
