Yes, also try AbeBooks clearing house, I have got deals in the past.
It should have a CD included.
The first edition is a lot cheaper at Abe's than the 3rd. Good enough for my needs I assume?
I have the 3rd edition so I have no idea how they differ.The first edition is a lot cheaper at Abe's than the 3rd. Good enough for my needs I assume?
I wasn't aware you were doing PCB milling.. There isn't a built in function for that..Will HSM Express do the isolation routing for PCBs too? I am really trying to avoid PCBGcode because I am forced to use Eagle. I really like Diptrace. I find Eagle confusing. I wish they would not have coupled PCNGcode so tightly to Eagle.
But if you can get the dxf file into it then there is a "trace" function that should work just fine..
Never tried it..
Engraving isn't a feature (yet) in HSM express.. Its in the full blown version though..Not just PCB milling. I plan to do engraving and cutting project boxes too. Just I was hoping it did the isolation for PCB. I will check out the trace function. Thanks.
| I | Please help explain this software I2C code! | Software & IDEs | 20 | |
| K | Can someone explain me what this code is doing | Programming & Languages | 6 | |
| S | explain this code if it is correct or not | Programming & Languages | 4 | |
| T | explain this code | Programming & Languages | 4 | |
| J | Can wise men explain this code to me? | Programming & Languages | 13 |
