Example question
33,186
First, get all three into the same form, namely
i_n(t) = I_N cos(ωt + θ_n)
Then determining how much one leads another becomes trivial.
screen1988
Joined Mar 7, 2013
310
In i_n(t) = I_N sin(ωt + θ_n) what is the range of θ_n?
-180 degrees to 180 degrees or 0 to 360 degrees?
I got two different results with the question i1(t) leads i3(t).
If θ_n is from -180 to 180 degrees then i1(t) leads i3(t) by 165 degrees.
If θ_n is from 0 to 360 degrees then i1(t) leads i3(t) by -195 degrees.
33,186
If θ_n is from -180 to 180 degrees then i1(t) leads i3(t) by -165 degrees.
It shouldn't matter what range you choose. Either way, you may need to normalize the answer, but the answers should be the same modulo 360°.
screen1988
Joined Mar 7, 2013
310
I realise I made a mistake. The first case is 165 degrees and the second is -195 degrees.
And as you said both are correct. There is an infinite number of the correct answers here?
33,186
Yes, though common practice is to reduce it to less than one complete revolution in either direction and to normally restrict even that to a total range of just one revolution overall.
