etymology of word "transistor"
PG1995
Joined Apr 15, 2011
832
Hi
I'm trying to understand the etymology of word "transistor". Please help me.
Merriam Webster states: transfer + resistor; from its transferring an electrical signal across a resistor.
Would you please tell me how does a transistor 'transfer resistance'? Thanks for your help.
Regards
PG
Hi-Z
Joined Jul 31, 2011
158
Wikipedia has 2 possible explanations:
"Transistor. This is an abbreviated combination of the words "transconductance" or "transfer", and "varistor". The device logically belongs in the varistor family, and has the transconductance or transfer impedance of a device having gain, so that this combination is descriptive."
"The way I provided the name, was to think of what the device did. And at that time, it was supposed to be the dual of the vacuum tube. The vacuum tube had transconductance, so the transistor would have 'transresistance.' And the name should fit in with the names of other devices, such as varistor and thermistor. And. . . I suggested the name 'transistor.'"
Zod
Joined Jul 3, 2011
13
I think the term "semiconductor" comes into play. Resistors in a way "semi" conduct. I don't believe it is truly an accurate description, but at the same time a transistor can act as a pot. Just muddying it further ;)
Frank987 Off-Topic 30
