ESR AND ELECTROLYTICS for eico 950b tester
pastinsain
Joined Aug 25, 2012
163
Hello everyone, I just recently purchased electrolytic filter caps in 8uf and 4uf 600v
I'm using them to restore an eico 950b and paco c20 capacitance bridge tester.
However, these have a high esr of 8ohms using my Mser-100 tester. The mser tester indicates that it's ok to use them if the UF of the caps being tested is under 10uf. The caps were purchased from a respected vendor in Canada that specializes in vintage electronics.
Question is, are the esr readings way too high for new aluminum electrolytics ?
bob2
Joined Jun 15, 2019
226
Hello pastinsain.
It must be all right.
From EPCOS datasheet.
4.7uf 450v.
ESR (max.).
120Hz-40Ohm.
10kHz-30Ohm.
Z (max.).
100kHz-16Ohm.
