ESP8266 Webserver very unstable
zazas321
Joined Nov 29, 2015
936
Hey. I have been working on my project for a while. I am using multiple Xbee devices to remotely read/write data to and from webserver. I am using NodeMCU-12 development board and I am having one problem with the webserver that ESP is creating.
C:
void setup() {
  Serial.begin(9600);
u8g2.begin();
  dht.begin();
  ina219.begin();
  // Connect to Wi-Fi network with SSID and password
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  // Print local IP address and start web server
  Serial.println("");
  Serial.println("WiFi connected.");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
  server.begin();
C:
void WEB_DISPLAY(){
  WiFiClient client = server.available();   // Listen for incoming clients
  if (client) {                             // If a new client connects,
    Serial.println("New Client.");          // print a message out in the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
Remotetemperature();
roomtemperature();
powersensor();
    while (client.connected()) {            // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        header += c;
        if (c == '\n') {                    // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("HTTP/1.1 200 OK");
            client.println("Content-type:text/html");
            client.println("Connection: close");
            client.println();
            // turns the GPIOs on and off
            if (header.indexOf("GET /5/on") >= 0) {
              Serial.println("GPIO 5 on");
              output5State = "on";
              setRemoteState(0x5);
             u8g2.setFont(u8g2_font_t0_11_tf);
             u8g2.setCursor(30, 30);
             u8g2.print("ON");
            } else if (header.indexOf("GET /5/off") >= 0) {
              Serial.println("GPIO 5 off");
              output5State = "off";
              setRemoteState(0x4);
             u8g2.print("OFF");
            // Display the HTML web page
            client.println("<!DOCTYPE html><html>");
            client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
            client.println("<link rel=\"icon\" href=\"data:,\">");
            // CSS to style the on/off buttons
            // Feel free to change the background-color and font-size attributes to fit your preferences
            client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
            client.println(".button { background-color: #195B6A; border: none; color: white; padding: 16px 40px;");
            client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
            // Web Page Heading
            client.println("<body><h1>ESP8266 Web Server</h1>");
            // Display current state, and ON/OFF buttons for GPIO 5
            client.println("<p>GPIO 5 - State " + output5State + "</p>");
            // If the output5State is off, it displays the ON button
            if (output5State=="off") {
              client.println("<p><a href=\"/5/on\"><button class=\"button\">ON</button></a></p>");
            } else {
              client.println("<p><a href=\"/5/off\"><button class=\"button button2\">OFF</button></a></p>");
            //DISPLAY TEMPERATURE
            float h = dht.readHumidity();
float t = dht.readTemperature();
               client.println("<body><h2>Temperature and humidity</h2>");
               client.println("<p>Temperature:");
               client.print(t);
               client.println("C</p>");
               client.print("<p>Humidity:");
              client.print(h);
              client.print("%</p>");
            // The HTTP response ends with another blank line
            client.println();
            // Break out of the while loop
            break;
          } else { // if you got a newline, then clear currentLine
            currentLine = "";
        } else if (c != '\r') {  // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
    // Clear the header variable
    header = "";
    // Close the connection
     client.stop();
    Serial.println("Client disconnected.");
    Serial.println("");
    ESP.reset();
I am basically using this guys code :
https://randomnerdtutorials.com/esp8266-web-server/
just slightly modified. When he is contorlling appliance, it seems to be working fine.
In my case, when I type in IP address to my browser. 90% of the times it continues to load the page for like 1 minute and then nothing appears, just white screen. However, sometimes the webserver would open but respond very slow and most of the time when I press a button to toggle the pin webbrowser will go non responding and continue to load..
Are there any solutions how to make ESP8266 webserver faster?
The server is really getting down and the main thing is that many users like me are getting affected by the server down and the work is not getting completed. I have also gone through because the server was not connecting.
zazas321
Joined Nov 29, 2015
936
Assuming you are using the Arduino IDE, where is your void loop()?
Where is WEB_DISPLAY() even called?
I call it in loop. Its working fine when I port-forward and use a host whereas when you use IP its much slower. That is very strange because even when you use a host it stil redirects me to same IP
Ya’akov
Joined Jan 27, 2019
10,291
Stick a sniffer on the client and see if it is trying to resolve the IP to a name when you access it directly.
