Im trying to track the ISS longitude and latitude. My sketch is coped from a book. compiles fine.
I bought a USB programmer and was able to run a simple blink sketch on the ESP8266, but when I put the ESP8266 back onto my Arduino UNO, the error message came up again, "esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header"
this is the full error message:
Arduino: 1.8.13 (Mac OS X), Board: "Generic ESP8266 Module, 160 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:128KB OTA:~438KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
/private/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/AppTranslocation/19D855D3-038B-4437-9F17-1CF5E076E5FA/d/Arduino-2.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /private/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/AppTranslocation/19D855D3-038B-4437-9F17-1CF5E076E5FA/d/Arduino-2.app/Contents/Java/hardware -hardware /Users/hill/Library/Arduino15/packages -tools /private/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/AppTranslocation/19D855D3-038B-4437-9F17-1CF5E076E5FA/d/Arduino-2.app/Contents/Java/tools-builder -tools /private/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/AppTranslocation/19D855D3-038B-4437-9F17-1CF5E076E5FA/d/Arduino-2.app/Contents/Java/hardware/tools/avr -tools /Users/hill/Library/Arduino15/packages -built-in-libraries /private/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/AppTranslocation/19D855D3-038B-4437-9F17-1CF5E076E5FA/d/Arduino-2.app/Contents/Java/libraries -libraries /Users/hill/Documents/Arduino/libraries -fqbn=esp8266:esp8266:generic:xtal=160,vt=flash,exception=legacy,ssl=all,ResetMethod=nodemcu,CrystalFreq=26,FlashFreq=40,FlashMode=dout,eesz=1M128,led=2,sdk=nonosdk_190703,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=2341_0043 -ide-version=10813 -build-path /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295 -warnings=none -build-cache /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_cache_672578 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.python3.path=/Users/hill/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=/Users/hill/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-4-b40a506.path=/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506 -prefs=runtime.tools.mkspiffs.path=/Users/hill/Library/Arduino15/packages/esp8266/tools/mkspiffs/2.5.0-4-b40a506 -prefs=runtime.tools.mkspiffs-2.5.0-4-b40a506.path=/Users/hill/Library/Arduino15/packages/esp8266/tools/mkspiffs/2.5.0-4-b40a506 -prefs=runtime.tools.mklittlefs.path=/Users/hill/Library/Arduino15/packages/esp8266/tools/mklittlefs/2.5.0-4-fe5bb56 -prefs=runtime.tools.mklittlefs-2.5.0-4-fe5bb56.path=/Users/hill/Library/Arduino15/packages/esp8266/tools/mklittlefs/2.5.0-4-fe5bb56 -verbose /Users/hill/Documents/Arduino/ISS_Tracker/ISS_Tracker.ino
/private/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/AppTranslocation/19D855D3-038B-4437-9F17-1CF5E076E5FA/d/Arduino-2.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /private/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/AppTranslocation/19D855D3-038B-4437-9F17-1CF5E076E5FA/d/Arduino-2.app/Contents/Java/hardware -hardware /Users/hill/Library/Arduino15/packages -tools /private/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/AppTranslocation/19D855D3-038B-4437-9F17-1CF5E076E5FA/d/Arduino-2.app/Contents/Java/tools-builder -tools /private/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/AppTranslocation/19D855D3-038B-4437-9F17-1CF5E076E5FA/d/Arduino-2.app/Contents/Java/hardware/tools/avr -tools /Users/hill/Library/Arduino15/packages -built-in-libraries /private/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/AppTranslocation/19D855D3-038B-4437-9F17-1CF5E076E5FA/d/Arduino-2.app/Contents/Java/libraries -libraries /Users/hill/Documents/Arduino/libraries -fqbn=esp8266:esp8266:generic:xtal=160,vt=flash,exception=legacy,ssl=all,ResetMethod=nodemcu,CrystalFreq=26,FlashFreq=40,FlashMode=dout,eesz=1M128,led=2,sdk=nonosdk_190703,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=2341_0043 -ide-version=10813 -build-path /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295 -warnings=none -build-cache /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_cache_672578 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.python3.path=/Users/hill/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=/Users/hill/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-4-b40a506.path=/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506 -prefs=runtime.tools.mkspiffs.path=/Users/hill/Library/Arduino15/packages/esp8266/tools/mkspiffs/2.5.0-4-b40a506 -prefs=runtime.tools.mkspiffs-2.5.0-4-b40a506.path=/Users/hill/Library/Arduino15/packages/esp8266/tools/mkspiffs/2.5.0-4-b40a506 -prefs=runtime.tools.mklittlefs.path=/Users/hill/Library/Arduino15/packages/esp8266/tools/mklittlefs/2.5.0-4-fe5bb56 -prefs=runtime.tools.mklittlefs-2.5.0-4-fe5bb56.path=/Users/hill/Library/Arduino15/packages/esp8266/tools/mklittlefs/2.5.0-4-fe5bb56 -verbose /Users/hill/Documents/Arduino/ISS_Tracker/ISS_Tracker.ino
Using board 'generic' from platform in folder: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3
Using core 'esp8266' from platform in folder: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3
Detecting libraries used...
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/include -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/lwip2/include -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=160000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/cores/esp8266 -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/variants/generic /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/sketch/ISS_Tracker.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/include -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/lwip2/include -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=160000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/cores/esp8266 -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/variants/generic -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/SPI /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/sketch/ISS_Tracker.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for ESP8266WiFi.h: [ESP8266WiFi@1.0]
ResolveLibrary(ESP8266WiFi.h)
-> candidates: [ESP8266WiFi@1.0]
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/include -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/lwip2/include -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=160000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/cores/esp8266 -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/variants/generic -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/SPI -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/sketch/ISS_Tracker.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for TimeLib.h: [Time@1.6]
ResolveLibrary(TimeLib.h)
-> candidates: [Time@1.6]
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/include -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/lwip2/include -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=160000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/cores/esp8266 -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/variants/generic -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/SPI -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src -I/Users/hill/Documents/Arduino/libraries/Time /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/sketch/ISS_Tracker.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Using cached library dependencies for file: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/SPI/SPI.cpp
Using cached library dependencies for file: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src/BearSSLHelpers.cpp
Using cached library dependencies for file: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src/CertStoreBearSSL.cpp
Using cached library dependencies for file: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src/ESP8266WiFi.cpp
Using cached library dependencies for file: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src/ESP8266WiFiAP.cpp
Using cached library dependencies for file: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src/ESP8266WiFiGeneric.cpp
Using cached library dependencies for file: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src/ESP8266WiFiGratuitous.cpp
Using cached library dependencies for file: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src/ESP8266WiFiMulti.cpp
Using cached library dependencies for file: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src/ESP8266WiFiSTA-WPS.cpp
Using cached library dependencies for file: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src/ESP8266WiFiSTA.cpp
Using cached library dependencies for file: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src/ESP8266WiFiScan.cpp
Using cached library dependencies for file: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src/WiFiClient.cpp
Using cached library dependencies for file: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src/WiFiClientSecureAxTLS.cpp
Using cached library dependencies for file: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.cpp
Using cached library dependencies for file: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src/WiFiServer.cpp
Using cached library dependencies for file: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src/WiFiServerSecureAxTLS.cpp
Using cached library dependencies for file: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src/WiFiServerSecureBearSSL.cpp
Using cached library dependencies for file: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src/WiFiUdp.cpp
Using cached library dependencies for file: /Users/hill/Documents/Arduino/libraries/Time/DateStrings.cpp
Using cached library dependencies for file: /Users/hill/Documents/Arduino/libraries/Time/Time.cpp
Generating function prototypes...
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/include -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/lwip2/include -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=160000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/cores/esp8266 -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/variants/generic -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/SPI -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src -I/Users/hill/Documents/Arduino/libraries/Time /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/sketch/ISS_Tracker.ino.cpp -o /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/preproc/ctags_target_for_gcc_minus_e.cpp -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/AppTranslocation/19D855D3-038B-4437-9F17-1CF5E076E5FA/d/Arduino-2.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/hill/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/signing.py --mode header --publickey /Users/hill/Documents/Arduino/ISS_Tracker/public.key --out /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/core/Updater_Signing.h
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/include -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/lwip2/include -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DNONOSDK22x_190703=1 -DF_CPU=160000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/cores/esp8266 -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/variants/generic -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/SPI -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src -I/Users/hill/Documents/Arduino/libraries/Time /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/sketch/ISS_Tracker.ino.cpp -o /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/sketch/ISS_Tracker.ino.cpp.o
Compiling libraries...
Compiling library "SPI"
Using previously compiled file: /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/SPI/SPI.cpp.o
Compiling library "ESP8266WiFi"
Using previously compiled file: /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/CertStoreBearSSL.cpp.o
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/include -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/lwip2/include -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DNONOSDK22x_190703=1 -DF_CPU=160000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/cores/esp8266 -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/variants/generic -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/SPI -I/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src -I/Users/hill/Documents/Arduino/libraries/Time /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi/src/BearSSLHelpers.cpp -o /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/BearSSLHelpers.cpp.o
Using previously compiled file: /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFiAP.cpp.o
Using previously compiled file: /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFiGeneric.cpp.o
Using previously compiled file: /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFi.cpp.o
Using previously compiled file: /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFiGratuitous.cpp.o
Using previously compiled file: /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFiSTA-WPS.cpp.o
Using previously compiled file: /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFiMulti.cpp.o
Using previously compiled file: /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFiSTA.cpp.o
Using previously compiled file: /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFiScan.cpp.o
Using previously compiled file: /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/WiFiClient.cpp.o
Using previously compiled file: /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/WiFiClientSecureBearSSL.cpp.o
Using previously compiled file: /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/WiFiClientSecureAxTLS.cpp.o
Using previously compiled file: /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/WiFiServer.cpp.o
Using previously compiled file: /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/WiFiServerSecureAxTLS.cpp.o
Using previously compiled file: /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/WiFiUdp.cpp.o
Using previously compiled file: /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/WiFiServerSecureBearSSL.cpp.o
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-ar cru /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFi.a /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/BearSSLHelpers.cpp.o
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-ar cru /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFi.a /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/CertStoreBearSSL.cpp.o
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-ar cru /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFi.a /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFi.cpp.o
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-ar cru /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFi.a /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFiAP.cpp.o
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-ar cru /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFi.a /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFiGeneric.cpp.o
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-ar cru /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFi.a /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFiGratuitous.cpp.o
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-ar cru /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFi.a /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFiMulti.cpp.o
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-ar cru /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFi.a /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFiSTA-WPS.cpp.o
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-ar cru /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFi.a /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFiSTA.cpp.o
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-ar cru /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFi.a /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFiScan.cpp.o
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-ar cru /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFi.a /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/WiFiClient.cpp.o
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-ar cru /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFi.a /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/WiFiClientSecureAxTLS.cpp.o
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-ar cru /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFi.a /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/WiFiClientSecureBearSSL.cpp.o
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-ar cru /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFi.a /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/WiFiServer.cpp.o
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-ar cru /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFi.a /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/WiFiServerSecureAxTLS.cpp.o
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-ar cru /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFi.a /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/WiFiServerSecureBearSSL.cpp.o
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-ar cru /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFi.a /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/WiFiUdp.cpp.o
Compiling library "Time"
Using previously compiled file: /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/Time/Time.cpp.o
Using previously compiled file: /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/Time/DateStrings.cpp.o
Compiling core...
Using precompiled core: /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_cache_672578/core/core_ae3730296692e6ea9bb7a43bcd829a04.a
Linking everything together...
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-gcc -CC -E -P -DVTABLES_IN_FLASH /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/ld/eagle.app.v6.common.ld.h -o /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/local.eagle.app.v6.common.ld
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-gcc -fno-exceptions -Wl,-Map -Wl,/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/ISS_Tracker.ino.map -g -w -Os -nostdlib -Wl,--no-check-sections -u app_entry -u _printf_float -u _scanf_float -Wl,-static -L/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/lib -L/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/lib/NONOSDK22x_190703 -L/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/ld -L/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sdk/libc/xtensa-lx106-elf/lib -Teagle.flash.1m128.ld -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,spi_flash_read -o /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/ISS_Tracker.ino.elf -Wl,--start-group /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/sketch/ISS_Tracker.ino.cpp.o /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/SPI/SPI.cpp.o /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/ESP8266WiFi/ESP8266WiFi.a /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/Time/DateStrings.cpp.o /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/libraries/Time/Time.cpp.o /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_cache_672578/core/core_ae3730296692e6ea9bb7a43bcd829a04.a -lhal -lphy -lpp -lnet80211 -llwip2-536-feat -lwpa -lcrypto -lmain -lwps -lbearssl -laxtls -lespnow -lsmartconfig -lairkiss -lwpa2 -lstdc++ -lm -lc -lgcc -Wl,--end-group -L/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295
/Users/hill/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/elf2bin.py --eboot /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/bootloaders/eboot/eboot.elf --app /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/ISS_Tracker.ino.elf --flash_mode dout --flash_freq 40 --flash_size 1M --path /Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin --out /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/ISS_Tracker.ino.bin
Creating BIN file "/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/ISS_Tracker.ino.bin" using "/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/bootloaders/eboot/eboot.elf" and "/var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/ISS_Tracker.ino.elf"
/Users/hill/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/signing.py --mode sign --privatekey /Users/hill/Documents/Arduino/ISS_Tracker/private.key --bin /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/ISS_Tracker.ino.bin --out /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/ISS_Tracker.ino.bin.signed --legacy /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/ISS_Tracker.ino.bin.legacy_sig
/Users/hill/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/sizes.py --elf /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/ISS_Tracker.ino.elf --path /Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin
Executable segment sizes:
IROM : 246908 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 26888 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1276 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 1020 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 25032 ) - zeroed variables (global, static) in RAM/HEAP
Using library SPI at version 1.0 in folder: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/SPI
Using library ESP8266WiFi at version 1.0 in folder: /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/libraries/ESP8266WiFi
Using library Time at version 1.6 in folder: /Users/hill/Documents/Arduino/libraries/Time
/Users/hill/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-size -A /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/ISS_Tracker.ino.elf
Sketch uses 276092 bytes (30%) of program storage space. Maximum is 892912 bytes.
Global variables use 27328 bytes (33%) of dynamic memory, leaving 54592 bytes for local variables. Maximum is 81920 bytes.
/Users/hill/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 /Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/upload.py --chip esp8266 --port /dev/cu.usbmodem14201 --baud 115200 --before default_reset --after hard_reset write_flash 0x0 /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino_build_921295/ISS_Tracker.ino.bin
esptool.py v2.8
Serial port /dev/cu.usbmodem14201
Connecting........_____....._____....._____....._____....._____....._____.....____Traceback (most recent call last):
File "/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/upload.py", line 65, in <module>
esptool.main(cmdline)
File "/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/esptool/esptool.py", line 2890, in main
esp.connect(args.before)
File "/Users/hill/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/esptool/esptool.py", line 483, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
_
Compiling sketch...
Compiling core...
esptool.py v2.8
_
