ESP32 using for measuring duty cycle
MentaniP2W
Joined Dec 15, 2021
I have to use timer on ESP32 to count the time when signal is high, there is way to set the timer and get is value after some time without use interrupts?
ericgibbs
Joined Jan 29, 2010
21,597
hiP2W,
Welcome to AAC.
I assume you are using the Arduino IDE, if yes, you could consider using the 'millis' time function.
E
