ESP32 using Deep Sleep & Light Sleep in same code
Brettjohnson7191
Joined Apr 28, 2022
23
Hello, I am working on some code right now for a project of mine. I need to be able to use light sleep and deep sleep in my code. The light sleep is used for a 10 second interval in which the ESP32 wakes up after and continues the code. This part works great as well as the rest of my code. However, when I write the code for entering deep sleep at the end of my program It keeps waking up at the 10 second interval. I believe I need to use something like esp_sleep_disable_wakeup_source(); / but am not sure what to add inside the argument any help would be appreciated. Thank you all!
C-like:
#define uS_TO_S_FACTOR 1000000ULL  /* Conversion factor for micro seconds to seconds */
#define TIME_TO_SLEEP  10
#define BUTTON_PIN_BITMASK 0x200000000 // 2^33 in hex     /* Time ESP32 will go to sleep (in seconds) */
RTC_DATA_ATTR int bootCount = 0;
void print_wakeup_reason(){
  esp_sleep_wakeup_cause_t wakeup_reason;
  wakeup_reason = esp_sleep_get_wakeup_cause();
  switch(wakeup_reason)
    case ESP_SLEEP_WAKEUP_EXT0 : Serial.println("Wakeup caused by external signal using RTC_IO"); break;
    case ESP_SLEEP_WAKEUP_EXT1 : Serial.println("Wakeup caused by external signal using RTC_CNTL"); break;
    case ESP_SLEEP_WAKEUP_TIMER : Serial.println("Wakeup caused by timer"); break;
    case ESP_SLEEP_WAKEUP_TOUCHPAD : Serial.println("Wakeup caused by touchpad"); break;
    case ESP_SLEEP_WAKEUP_ULP : Serial.println("Wakeup caused by ULP program"); break;
    default : Serial.printf("Wakeup was not caused by deep sleep: %d\n",wakeup_reason); break;
void WINDUP_MOTOR (){
  Serial.println("RESETING.....");
  digitalWrite(18, HIGH);
  digitalWrite(19, LOW);
  delay(5500);
  digitalWrite(18,LOW);
  delay(100);
void WINDUP_MOTOR_SLK (){
   Serial.println("ADDING SLACK");
  digitalWrite(18, LOW);
  digitalWrite(19, HIGH);
  delay(1000);
  digitalWrite(19,LOW);
  delay(100);
void REMOVE_MOTOR_FW (){
  Serial.println("REMOVED");
  digitalWrite(17, HIGH);
  digitalWrite(16, LOW);
  delay(750);
  digitalWrite(17,LOW);
  delay(100);
void REMOVE_MOTOR_RV (){
  digitalWrite(17, LOW);
  digitalWrite(16, HIGH);
  delay(500);
  digitalWrite(16,LOW);
  delay(100);
   Serial.println("READY TO GO AGAIN");
void TRIGGER_MOTOR (){
  delay(750);
  digitalWrite(5,LOW);
  delay(100);
  Serial.println("FIRED");
void SLEEP(){
  esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
  delay(50);
  Serial.println("Going to sleep now");
  Serial.flush();
  esp_light_sleep_start();
void setup() {
  pinMode(18, OUTPUT);
  pinMode(19, OUTPUT);
  pinMode(17, OUTPUT);
  pinMode(16, OUTPUT);
  pinMode(5, OUTPUT);
void loop() {
  Serial.begin(115200);
  delay(50);
  print_wakeup_reason();
  TRIGGER_MOTOR();
  delay(50);
  SLEEP();
  WINDUP_MOTOR ();
  WINDUP_MOTOR_SLK ();
  REMOVE_MOTOR_FW ();
  REMOVE_MOTOR_RV ();
  esp_sleep_enable_ext0_wakeup(GPIO_NUM_33,1);
  esp_deep_sleep_start();
