Equivalent Substitute - MOSFET Cross-Reference
justinvil1103
Joined Apr 6, 2016
52
I am trying to find a replacement a current MOSFET ( ZXMN3A14FTA) with a Max Vgs =+/-20V, but I have found an Equivalent Substitute with Max Vgs = +/-12V. I don't think it would be an issues, but just wanted your thoughts or someone has any other ideas regarding picture below.
Thanks,
WJ
MrSalts
Joined Apr 2, 2020
2,767
If Vgs,will never be over 12V, I think you'll be fine. You can add a protection Zener Diode (10v) if you are concerned about higher voltage spikes. This is a very common solution to limit gate voltage. Don't forget a current limiting resistor.
