equipment recommendations?
magnet18
Joined Dec 22, 2010
1,227
I'm looking to get a tax return gift for myself! It's been way too ling since I got any good equipment :p
I'm trying to decide between-
a good signal generator (currently using an old one with just a sloppy sine wave output)
a good bench power supply (currently using a modified computer power supply)
or something just nice to have, like a circuit board vice or magnified worklight or solder reflow setup for SMD soldering
I'm leaning towards the power supply or the signal generator, looking in around the $99 dollar range, but I want something that will last many years, so if it will pay for itself I may go higher
Anyone have any recommendations?
Anything at your bench you absolutely love that I didn't mention?
tshuck
Joined Oct 18, 2012
3,534
If you want something to suit future, potential needs, an arbitrary waveform generator is nice, but without a good bench supply, the point may be moot.
If price is the issue, get the power supply, you can get a decent one cheaper than an arbitrary waveform generator...
THE_RB
Joined Feb 11, 2008
5,438
Seconded. I have multiple bench PSUs and could not work without them.
If your current supply is a modified PC PSU, then you REALLY need to buy a decent adjustable PSU with voltmeter and ammeter, preferably with adjustable current limiting too.
Dual variable supply, 0-30v, 5A. $253, free postage.
http://www.ebay.com.au/itm/LCD-Dual...Electrical_Test_Equipment&hash=item1e8839dd84
0-30v 3A, $190.
http://www.ebay.com.au/itm/LCD-Disp...Electrical_Test_Equipment&hash=item3f303e746b
And there are a lot more options. :)
alfacliff
Joined Dec 13, 2013
2,458
that depends on youe interests, I would not do without a good counter, programable rf signal generator, high frequency scope, and my spectrum analyzer, which I had to build myself.
cliff
magnet18
Joined Dec 22, 2010
1,227
What you say makes sense, the power supply will definitely be most useful
What would you guys recommend for specs?
I can't imagine needing more than 30 volts or 3 amps, is there anything else I need to watch for?
tshuck
Joined Oct 18, 2012
3,534
There was a thread on here a little while back with someone opening a similar power supply up to find the thing wired completely wrong (I think the case was live).
That said, I'd buy one if not just to modify. My one qualm would be that I'd like a +/- 30V @5A current-limited supply.
mcgyvr
Joined Oct 15, 2009
5,394
With any "cheap Chinese" stuff its always buyer beware.. You could get a unit that works perfect for years or have one that completely falls apart.
I've bought 2 "similar" supplies Protek 6003L (now obsolete) but they have been working just fine and are used in a "production/professional" environment and not just hobby occasional use.
My suggestion with any "cheap Chinese" stuff is never assume its perfect..never assume its safe..use extra caution.
Personally, I rarely use a power supply, preferring batteries mainly. If I need it to be fairly accurate, then building a regulator is good project. I almost never need to use a variable power supply with an accurate readout- that's what DVM's are for. I guess it depends on what you want to use it for. If I need something with higher voltage for, say, a radio, building a power supply is also a good project.
So my vote would be for a good signal generator or function generator- I could not work without one. Preferably with a (somewhat) leveled output, like an older HP lab grade.
Just offering a different opinion, everyone has their preferred working methods and areas of interest.
GRNDPNDR
Joined Mar 1, 2012
545
I just got a Mastech HY3005F-3 which is actually decent, or is now that I had taken it apart to repair it (it arrived broken) and reassembled much of it properly, as it wasn't correctly assembled before.... in too much of a hurry to get it together.
magnet18
Joined Dec 22, 2010
1,227
did some research, mastechs appear OK, if it's unlabeled, or something clearly copying it's probably crap (like the one I linked)
I think I'll be better getting a used good one, like an HP or such
Gonna check the surplus store friday after school see if they have anything :)
THE_RB
Joined Feb 11, 2008
5,438
GRNDPNDR
Joined Mar 1, 2012
545
I purchased mine through electronix express on amazon for $180.
It arrived as an RSR unit, Not Mastech which I was pretty unhappy about but they claim that they had Mastech rebrand the units with their name (RSR)
Not really sure what to think of that though as one person in an amazon review states that RSR is their own company and not a rebrand.
