Envelope detector circuit simulation
Blue_Electronx
Joined Jun 10, 2019
112
Below there's a picture of the circuit I'm simulating. I've also attached the asc file. The op amp used is MC33172D. I tried to find a model online but I didn't have success importing it to LTspice. So I'm using the LT1112. I have the following questions regarding the circuit operation and the simulation:
1- What are the purposes of C3 and C4? Coupling capacitors?
2- Why is the output signal a little bit shifted right?
3- Why is the output signal a little bit less? diode drop?
4- At last, why the output peak voltage is less in the negative cycle?
djsfantasi
Joined Apr 11, 2010
9,237
C3 is a power filtering capacitor; C4 is a coupling cap.
There are two sources of the shift. Capacitor C2 adds a little. But capacitor C4 is the main source. Since C4 is the input to the op-amp, it introduces lag represented by 3 x the RC time constant. I’m not sure where you got your values from, but IMHO C4 is too large. It may be needed, but I’d use 0.1μF. I can’t read the resistor value, so I recommend you do the calculations for the expected shift and see if they are congruent to your results.
No. Likely because op-amps aren’t truly rail-to-rail. If you input 5V, you’ll always get less than 5V out. The LT1023 only goes to 4.3V max. I didn’t look up the LT1112. The min/max rail outputs can be found on the datasheets. There are rail-to-rail op-amps that get closer to Vcc but you never get 100%.
During the negative cycle. The caps are discharging. So the envelope will dip.
ericgibbs
Joined Jan 29, 2010
21,572
hi,
I would say C3 purpose is to act as a filter to remove any high frequency noise.
Remove C4 , it unbalances the Vout at 'ct', with the C4 in the signal is offset from zero.
Also R1/D1 are not the same loading on the negative half cycle as the positive half cycle, as are D2 and R2.
Reduce R1 to 460K
The delay at the output Vout is due to the charge/discharge cycle of C2
Who designed the circuit.?
E
danadak
Joined Mar 10, 2018
4,057
Of course this can be done with a UP pretty easily.....in case
you also need intelligence and other control in system.
Regards, Dana.
Blue_Electronx
Joined Jun 10, 2019
112
Eric, I haven't tried it. I'll do it in a while. I have attached below the circuit which is connected to the output of the circuit in post #1.
AnalogKid
Joined Aug 1, 2013
12,276
Another source of phase shift (delay) is D2-C3. The equivalent resistance of D2 forms an R-C circuit with C3. This circuit has attenuation and phase shift, both of which change as a function of the frequency of the signal.
ak
KL7AJ
Joined Nov 4, 2008
2,229
C4 shouldn't be too critical, it only has to be adequate to pass the lowest audio frequencies of interest. However C3 IS critical. There is a maximum value that this can be before you start seeing "diagonal clipping" or "failure to follow distortion." There is a formula for the optimum value for C3, but it's lost in the recesses of my cranium right now. I'll try to dredge it up. It is dependent on both the bandwidth AND modulation depth.
