Enroll Finger print creates issues; Adafruit Library
Vindhyachal Takniki
Joined Nov 3, 2014
598
1. I am using Uno, finger print module & Adafruit library.
2. With using all the library all the function works ok, like delete, scan but i have some issues in Enroll function.
3. Enroll function is below, it is same, except some minor changes & I had a small key_read function, in case user wants to exit. key_read is small non-blocking function, read a variable only, which get set/reset in ISR only, so minimal code there.
4. Problem is :
a) When first scan is done, it is ok.
b) next it ask for remove finger & place again.
c) now doing that & place finger again, code many times gives finger mismatch.
d) 9 out of 10 times it is giving mismatch . Although I am doing the same way every-time.
5. Same happens if I use En-roll example from Adafruit also.
6. What could be the error?
7. One possible error I think in Adafruit library there is variable "confidence", which check the matching level of both. Might be it is set to very high value, but in library I didn't find where to set it low.
Code:
uint8_t add_fingerprint_id(uint16_t id , uint8_t *r_key)
    uint8_t point = 255U;
    uint8_t key = no_key;
    uint8_t breakloop;
    uint8_t next = 0U;
    lcd.setCursor(0 , 3);
    lcd_string_const(add_place_str);
    serial_string_nl_const(add_place_str);
/* clear key vars */
    clear_key_vars();
    breakloop = 0U;
    while(0U == breakloop)
        point = finger.getImage();
        switch(point)
            case FINGERPRINT_OK:
                lcd_string_const(add_taken_str);
                serial_string_nl_const(add_taken_str);
                breakloop = 1U;
            break;
            case FINGERPRINT_NOFINGER:
                lcd_string_const(add_no_finger_str);
                serial_string_nl_const(add_no_finger_str);
            break;
            case FINGERPRINT_PACKETRECIEVEERR:
                lcd_string_const(add_comm_err_str);
                serial_string_nl_const(add_comm_err_str);
            break;
            case FINGERPRINT_IMAGEFAIL:
                lcd_string_const(add_image_err_str);
                serial_string_nl_const(add_image_err_str);
            break;
            default:
                lcd_string_const(add_unknown_err_str);
                serial_string_nl_const(add_unknown_err_str);
            break;
    /* read the key */
        key = key_read();
        if(EXIT_KEY == key)
            breakloop = 1U;
            next = 1U;
    if(0U == next)
        breakloop = 0U;
        point = finger.image2Tz(1);
        switch(point)
                lcd_string_const(add_image_conv_str);
                serial_string_nl_const(add_image_conv_str);
                breakloop = 1U;
            break;
            case FINGERPRINT_IMAGEMESS:
                lcd_string_const(add_image_messy_str);
                serial_string_nl_const(add_image_messy_str);
                next = 1U;
            break;
                next = 1U;
            break;
            case FINGERPRINT_FEATUREFAIL:
                lcd_string_const(add_no_feature_str);
                serial_string_nl_const(add_no_feature_str);
                next = 1U;
            break;
            case FINGERPRINT_INVALIDIMAGE:
                next = 1U;
            break;
            default:
                next = 1U;
            break;
    /* read the key */
        key = key_read();
        if(EXIT_KEY == key)
            breakloop = 1U;
            next = 1U;
    if(0U == next)
        lcd_string_const(add_remove_str);
        serial_string_nl_const(add_remove_str);
        delay(2000);
        point = 0U;
        breakloop = 0U;
            if(FINGERPRINT_NOFINGER == point)
                breakloop = 1U;
        /* read the key */
            key = key_read();
            if(EXIT_KEY == key)
                breakloop = 1U;
                next = 1U;
    if(0U == next)
        lcd_string_const(add_again_str);
        serial_string_nl_const(add_again_str);
        point = 255U;
        breakloop = 0U;
            switch(point)
                    breakloop = 1U;
                break;
                break;
                break;
                break;
                default:
                break;
        /* read the key */
            key = key_read();
            if(EXIT_KEY == key)
                breakloop = 1U;
                next = 1U;
    if(0U == next)
        breakloop = 0U;
        point = finger.image2Tz(2);
        switch(point)
                breakloop = 1U;
            break;
                next = 1U;
            break;
                next = 1U;
            break;
                next = 1U;
            break;
                next = 1U;
            break;
            default:
                next = 1U;
            break;
    /* read the key */
        key = key_read();
        if(EXIT_KEY == key)
            breakloop = 1U;
            next = 1U;
    if(0U == next)
        lcd_string_const(add_create_str);
        serial_string_nl_const(add_create_str);
        point = finger.createModel();
        if(FINGERPRINT_OK == point)
            lcd_string_const(add_match_str);
            serial_string_nl_const(add_match_str);
        else if(FINGERPRINT_PACKETRECIEVEERR == point)
            next = 1U;
        else if(FINGERPRINT_ENROLLMISMATCH == point)
            lcd_string_const(add_mismatch_str);
            serial_string_nl_const(add_mismatch_str);
            next = 1U;
        else
            next = 1U;
    /* read the key */
        key = key_read();
        if(EXIT_KEY == key)
            breakloop = 1U;
            next = 1U;
    if(0U == next)
        point = finger.storeModel(id);
            lcd_string_const(add_store_str);
            serial_string_nl_const(add_store_str);
            next = 1U;
        else if(FINGERPRINT_BADLOCATION == point)
            lcd_string_const(add_not_store_str);
            serial_string_nl_const(add_not_store_str);
            next = 1U;
        else if(FINGERPRINT_FLASHERR == point)
            lcd_string_const(add_flash_err_str);
            serial_string_nl_const(add_flash_err_str);
            next = 1U;
        else
            next = 1U;
    /* read the key */
        key = key_read();
        if(EXIT_KEY == key)
            breakloop = 1U;
            next = 1U;
    if(EXIT_KEY == key)
        *r_key = EXIT_KEY;
    else
        *r_key = no_key;
    delay(2000);
    return point;
} /* function ends here */
