A engineered continuous wave signal source at the ISM frequency of 13.56Mhz. This will be for a closed (non-signal radiating) application. Power level of at least 10 watts into a 50 ohm non reactive load. Harmonic performance is not specified. The restriction requiring only a 12 volt power source does not apply to this project.
NOTE: the maximum input to the spectrum is 1 watt so you must use an appropriate RF WATTMETER and dummy load.
Need help with design process
- block diagram
- schematic with simulation
- parts
- detailed explanation
