Hi Guys,
I'm Using energia to write a feedback code for boost converter using EK-TM4C123GXL but I can't set the frequency and get the error in the pic below
can any one help
can any one help
Boost Converter Feedback:
* This is an example code for a BOOST converter circuit made with arduino + feedback
* I've used arduino NANO. We have to set the timer of the PWM on pin D3
* The feedback is connected to A1 and we set the desired voltage with a
* potnetiometer connected to A0.
* Subscribe: http://www.youtube.com/c/electronoobs
* webpage: http://www.electronoobs.com/eng_circuitos_tut10.php
int potentiometer = A0; //The input from the potentiometer is A0
int feedback = A1; //The feedback input is A1
int PWM = 3; //Digital pin D3 por PWM signal
int pwm = 0; //Initial value of PWM width
void setup() {
pinMode(potentiometer, INPUT);
pinMode(feedback, INPUT);
pinMode(PWM, OUTPUT);
TCCR2B = TCCR2B & B11111000 | B00000001; // pin 3 and 11 PWM frequency of 31372.55 Hz
void loop() {
float voltage = analogRead(potentiometer); //We read the value of the potentiometer, which is the desired value
float output = analogRead(feedback); //We read the feedback, which is the real value
//If the desired value is HIGHER than the real value, we increase PWM width
if (voltage > output)
pwm = pwm+1;
pwm = constrain(pwm, 1, 254);
//If the desired value is LOWER than the real value, we decreaase PWM width
if (voltage < output)
pwm = pwm-1;
analogWrite(PWM,pwm); //Finally, we create the PWM signal
