MODERATOR: Your thread has been moved to the Homework Help forum. All coursework related questions must be posted to that forum because AAC rules limit the help a member may provide to students working on school projects. Assistance is restricted to guidance with your own work. The question as you’ve written it may not be directly answered under these rules. Please explain your own efforts at a solution if you want help here.
Please I need a full guideline on how to build an embedded system using any processing hardware( microcontroller/ soft processor), of your choice to perform :
i. receive external inputs,
ii process the inputs and
iii generate some outputs
Overall, I need the:
i. Circuit diagram
ii. Memory Mapping
iii Program design and coding
Thanks.
i. Circuit diagram
ii. Memory Mapping
Thanks.
