Electroniques/English/Cirlog/transistor_xor_gate.html
gjo
Joined May 22, 2013
43
I've been trying to figure out this circuit and I cannot understand how Q3 and Q4 receive base voltage and how the output of those parallel transistors is high or positive when both inputs are either both 0 or both 1.PXL_20210617_163119299.jpg
Papabravo
Joined Feb 24, 2006
22,111
They don't "receive" base voltage. They are diode-connected transistors. The base and the collector will always be at the same voltage - about 0.7 volts less than the emitter.
gjo
Joined May 22, 2013
43
That makes sense now. Could you explain a little more on how this circuit output is high when negative voltage is applied. Thanks
Papabravo
Joined Feb 24, 2006
22,111
There is a single 6V power supply, so all voltages will be between GND and +6V. there are no negative voltage that can be "applied.
The inputs S1 and S2 can only be high or floating. When they are floating no current flows in R1 or R2. When no current flows through a resistor the voltage is essentially the same on both ends and the collector base junctions of Q1 and Q2 are effectively at ground (negative side of the battery)
Deleted member 115935
Joined Dec 31, 1969
It is for a hobbyist club.
fantastic,
I did not realise such clubs still existed,
as a "kid" my school had such clubs, crystal radios were the normal, the wizards made single transistor radios....
Can I ask where in the world you are,
