Electronics Transistor
pijolysss
Joined Nov 30, 2017
17
hello,
Im student, Im reading the book "the art of electronics - horowitz hill", There is a part of the book wich it has "bad circuits", i would like to know whats the problem in that circuits(check pictures),
whats wrong and why in each circuit?
Thanks to all!
OBW0549
Joined Mar 2, 2015
3,566
In both figures, the wrong kind of transistor is used: in pic1 the transistor should be a PNP, not an NPN; and in pic2 the transistor should be an NPN, not a PNP.
38,507
The normal current flow through a transistor is in the direction of the emitter arrow.
That's how you determine which polarity transistor to use in a circuit.
hobbyist
Joined Aug 10, 2008
892
I don't know if you were taught this or not yet,
When you see the phrase above, it is referring to conventional current flow, (positive current), it is not referring to electron current flow, as have been taught about a flashlight circuit.
