Electronic Switches
Tonyr1084
Joined Sep 24, 2015
9,744
Are you talking about the arcs that occur in a switch when contact is made or broken? If that's your question then no, transistors do not arc. However, if you're wanting to create an arc and control it with an electronic source, yes; they're called ignition modules. Of course they require more than just an electronic switch; they require a power source and either a large inductive source or capacitive source. A little more clarification on what you mean will help get a better answer.
