Electromagnetism
user123456
Joined Jan 26, 2014
12
What is the force of attraction between a north and south pole separated by air? The flux density in the air is 0.84 Tesla and the rectangular poles measure 2cm by 3 cm. (168N)
F = B^2/2u0
0.84^2/2 x 1.257 x 10^-6
Not getting 168Newtons, can anyone please give me a hand here?
33,218
Could you show your work? With units?
If
F = B^2/(2μ0)
What are the units on B?
What are the units on μ0?
What are the units when you divide the first by (twice) the second?
33,218
If
F = B^2/(2μ0)
Well, since the OP can't be troubled to answer these questions, I guess I will.
The units on B are tesla, which is (Ns)/(Cm)
The units on μ0 are H/m or N/(A^2)
Thus, the units of B^2/(2μ0) are [(Ns)^2/(Cm)^2]*[(A^2)/N]
which reduce to N/(m^2)
Thus, a simple dimensional analysis reveals not only that the equation given simply cannot yield the desired answer, but gives a really strong indication of exactly what needs to be done in order to correct it.
But, hey, units are just a troublesome bother that only waste time.
33,218
F = \frac{B^2 A}{2 \mu_0}
F = \frac{(0.84 T)^2 (2 cm \cdot 3 cm)}{2 \( 4\pi \cdot 10^{-7} \frac{N}{A^2} \)}
F = \frac{ \( 0.84 \frac{Ns}{Cm} \)^2 (2 cm \cdot 3 cm)}{2 \( 4\pi \cdot 10^{-7} \frac{N}{\(C/s\)^2} \)}
F = 1684000 \ \( \frac{ N^2 C^2 s^2 cm^2 }{N C^2 s^2 m^2} \)
F = 1684000 \ \( \frac{ N \ cm^2 }{m^2} \)
F = 1684000 \ \( \frac{ N \ cm^2 }{m^2} \) \cdot \( \frac{1 m}{100 cm} \)^2
F = 168.4 N
See how wasting all that time on tracking units saves a lot of time?
33,218
You are right. That was an editing typo when doing a final fix-up of the LaTeX script.
Thanks for catching it!
