+ Lots of skill to get the cutout for the fan so symmetrical with the nice curve. My hat is off to you.table saw and an old blade.![]()
The hole was done with a drill press and a dremal.+ Lots of skill to get the cutout for the fan so symmetrical with the nice curve. My hat is off to you.
--ETA: I'd suggest Black "capscrews" that use an allen wrench for all externally visible fasteners. It makes things look a lot cleaner, and you can get feet that fit right over them so the box doesn't scratch anything.
ThanksGood job !!!!!!
The load was the coils I assume?I still have the scope so I hooked it up with the ground probe to the gates of T7/T8 and all the others to each other gate.
yes, measure between ground and the outputs of the 4025 and 4049 and post the results.I'm sorry that's what I meant, I connected all of the probes to the "drains" the ground was to T7/T8 and that's what the scope is showing, and there was no load at the time. Because it's not flipping, I'm assuming that it's because of either the 4025 or the 4049. Is there a way to test those?
I get them personally from a local hardware store like Ace Hardware, any of the "old style" hardware stores that have a few walls of drawers to choose fasteners from. They also sell the feet that go over the screws.The hole was done with a drill press and a dremal.
Excellent idea for the fasteners, I just used what was available. Do you have a link as to where I can find them?
if I understand correctly. im removing one end of the the 10 ohm resistor and then supplying 12v to the output (pin#9) of the 4025? is that correct? is that some sort of reset?If that's the case, open the resistor that is connected to the 4025s output and connect it to +12V.
Then check the 4025s output again.
NOOOO, please don't !then supplying 12v to the output (pin#9) of the 4025? is that correct? is that some sort of reset?
got it. makes sense...does it matter what side of the resistor I remove? can I supply the full 13v to the FET? or do I HAVE to go through a resistor? its easy to remove the connection between the circuit boards than it would be to remove the resistor..NOOOO, please don't !
The output remains open and you measure with the scope if there is really no pulse while there should be (due to the inputs changing between all zero or one at HIGH level)
The end of the resistor you opened you tie to 12V for this test, just to let the MOSFETs gates not floating.
Is the 4025 connected to the 4017 as per post 230?here are the 4017 outputs 1,0 and 2 (T4, T2 & T6) respectively.
You could do that, just to make sure, you only need to measur ethe output for that, the inputs are ok as we have seen.do you still need me to remove the resistor from the output and test it alone?
| Thread starter | Similar threads | Forum | Replies | Date |
| J | 10 nanofarad electrolytic capacitor | General Electronics Chat | 38 | |
| 7 | Should I clean up my electronics room? | Off-Topic | 31 | |
| H | Questions on RFIC and Electromagnetic design | Homework Help | 1 | |
| A | Electromagnet | General Electronics Chat | 92 | |
| R | Electromagnet Turns And Same Field generated?? | General Electronics Chat | 5 |
