E-cigarette circuits
jgreene44
Joined Dec 8, 2016
108
I have a question about E-cig. circuits. I just recently opened one. what im not understanding is why does it even have a controller? seems what the board wants to output is low voltage high current. that could be done with a direct connection from the battery to the coil. adjustment could be thru a simple potentiometer? least that's what I'm thinking the controller on the circuit board seems to be controlled by a pot. anywayz? so ya I'm wondering whats the deal with the board? thanks so much in advance.
Dodgydave
Joined Jun 22, 2012
11,395
The board will be controlling the current to a safe level, possibly temperature control and monitoring the battery voltage before it gets to a minimum working voltage.
jgreene44
Joined Dec 8, 2016
108
that all makes since. i could see someone burning a coil if left with only a pot. to adjust the flow or damaging it by running it to low?? ummm not real sure on that aspect. well no i could see use in that as well. even manually adjusted you only want your battery to run but so low.... ok its all coming clear i think. awsome. thanks for the input!
GopherT
Joined Nov 23, 2012
8,009
Also, these devices use a oscillating on/off to control the temp (turning up power means more fraction at full power than off, turning down means increasing time in off state vs on state). This change of duty cycle is known as pulse width modulation.
If you try to control with a potentiometer, the potentiometer will get hot as it limits current flow to your device and heat/energy is wasted (battery life is wasted).
Becca Be
Joined Jun 7, 2021
Ok but what about all this for a disposable e-cig. 1 time use, no adjusting heat nor need to?? Then why so much put into something that's self sufficiently maintained until thrown away!?
xox
Joined Sep 8, 2017
936
Simple. Electronics are relatively cheap. Keeping material and assembly costs below certain threshold (say 30%) will generate sufficient profits at high volume.
