Driving an 8 ohm speaker with common collector circuit
Status
Not open for further replies.
createdtowatch worldcup
Joined Oct 4, 2018
11
Hello everyone, I have not yet put values in my circuit. The first 2 stages should provide a total voltage gain of 75. Will this circuit layout able to drive the 8 ohm speaker ?(I forgot to add two voltage divider resistors before the darlington)
danadak
Joined Mar 10, 2018
4,057
Do you need to do this discrete ? There are so many
low cost audio amp ICs that have all the protections
and low distrortion, and easy to use. Class D versions
getyou h igh efficiency as well
Regards, Dana.
Joined Oct 4, 2018
11
Regards, Dana.
I was given to use only BJT npn , no I need to design from the most basic elements
AnalogKid
Joined Aug 1, 2013
12,268
Yes, but not very well. The darlington can source lots of current into the speaker, but the only path to sink current out of the speaker is through the darlington's emitter resistor. This means the amplifier's output impedance is not symmetrical. The smaller the resistor, the better the audio, but also the more heat the circuit will dissipate. A class A amplifier is very inefficient. It is common for a circuit like this to dissipate 2 watts in heat for every 1 watt that goes into the speaker.
ak
Status
