Drill charger
papa2one2003
Joined Apr 23, 2017
18
I am looking to find out what size fuse is used in a Coleman power mate 18v drill charger input 120vac 60hz 46w
Output 20.5v 1.4a 28.5va.
MaxHeadRoom
Joined Jul 18, 2013
30,785
It is usual to find the fuse No. stamped on one end cap, look the number up and it will indicate the nature of the fuse, FB. SB, etc.
Max.
Dodgydave
Joined Jun 22, 2012
11,395
Only thing i can suggest is the cells are faulty, there doesn't seem to be any intelligence on the charger to detect faulty cells, only a third pin for temperature sensing, are there any chips on the underside?
papa2one2003
Joined Apr 23, 2017
18
Does it still charge the first battery correctly (after you've discharged it a bit, that is)?
I put the fuse in and it charged the first battery fine then this morning I tried the second battery and 2seconds after I put in 2nd battery the charge light went out took that battery out tried first one again no lights on it I assumed the fuse blew again
Dodgydave
Joined Jun 22, 2012
11,395
Can you take a picture of the trackside, and the semiconductor on the heatsink and a closer focused shot of the components on the pcb, then we can work out the circuit diagram.?
