Doubt in comparison routine
massanetabr
Joined Jun 3, 2019
44
Guys, I'm being beaten up to do the following asm routine for pic 16F877.
I have A and B, both range from 0 to 100 and I would like to do the following routine
If A = B, ok don't do anything in C
If A+5 > B, increase C
If A-5 < B, decrease C
massanetabr
Joined Jun 3, 2019
44
I only want to increase or decrease C if the difference between A and B is 5 for one side or for the other side.
A = 50
B = 44, increment C
B = 45, increment C
B = 46, do nothing
B = 56, decrease C
B = 55, decrease C
B = 54, do nothing
atferrari
Joined Jan 6, 2004
5,022
I always work out the flow diagram and once satisfied with it, I write the code. This last becomes a simple clerical task.
Robin66
Joined Jan 5, 2016
281
The pseudo code is:
if(A+5 > B)
C++;
else if(A-5 < B)
C--;
end
This is enough for you to attempt to write the asm
click_here
Joined Sep 22, 2020
548
I think that the problem that the op was having is that there is no < or > in the PIC assembly language.
To work out if it's < or > the user needs to subtract one number from the other and see if the zero/carry bit is set in the status register
cmartinez
Joined Jan 17, 2007
8,852
The OP has probably already seen through that and solved the problem. It would be real nice if he were to report back and post his solution out of simple courtesy, though.
