Hi! I want to control a 24V BLDC (mini spindle) at max 6A I´ve got with an ESC (electronic speed controller), used in RC drones, planes, cars, boats..
I know some ESCs have forward/reverse settings, acceleration settings and so on, and some can be programmed to tune it´s settings
My doubt is.. as they´re made for flying, and not to control a spindle, can an ESC have it´s speed set to a minimum desired (I could control it with an arduino) but also mantain high torque (high currents) to prevent it from stopping when facing an attempt to stop it´s shaft from spinning? In my case, close to 6A ? My goals are to vary it from 2.000 RPM to 40.000 RPM.
I tried this BLDC controller I bought over aliexpress.com
https://www.aliexpress.com/item/DC-...32684492208.html?spm=2114.13010608.0.0.BA98S5
And although it worked, at lower speeds it doesn´t mantain high torque (currents don´t raise before stopping, I can stop it with my fingers,at low speeds), so it doesn´t suit my needs..
Does an esc try to sustain torque if at lower speeds I try to stop it´s shaft from rotating, by increasing its current? I could control the max allowed current with an arduino also. Can it be programmed to do so?
Thanks for reading!
Thanks for reading!
