Does this IGBT bridge meaningless ?
Hasan2019
Joined Sep 5, 2019
210
Hello My Dear Friends!
Hope this post finds you well.
I am trying to develop a AC to DC rectifier 110V/50 A range.
Feeling that I am doing wrong on making the full bridge or half bridge portion.
The IGBT module I am using is FF75R12RT4, https://www.infineon.com/dgdl/Infine...2805fd8fd76151
One module contains 2 IGBT that makes me confusing!
I need to understand my switching topologies first
Take a look my diagram, how the current flows back from primary winding of TR for a full cycle?
1. When point A is positive then Q2 conducts, Q1 is OFF?
2. When point A is negative then Q1 conducts Q2 is OFF?
3. When point B is positive then Q4 conducts, Q3 is OFF?
4. When point B is negative then Q3 conducts Q4 is OFF?
Freewheeling built on doides are available, whats 2uF high voltage is doing here?
ci139
Joined Jul 11, 2016
2,038
? are you overthinking (the point A is unlikely neg. . . . ) -- the upper fig. (a half bridge with K sources) is ok
-- the lower one however is configured mistily (i don't want to dig into this (not my area of comfort))
but either you need to swap lower transistors . . . or other that allows you to set AC/SqWv to T2
the input polarity
