Does this have a high common mode or is it floating
sirch2
Joined Jan 21, 2013
1,079
I've been putting together a geophysics resistivity unit (see my other threads) and I have a question, given the block diagram below is there a high common mode voltage across the ADXL1115 or is it floating if the Inverter isolates the battery from the 120V side?
ericgibbs
Joined Jan 29, 2010
21,642
Hi Sirch,
Please add the 0V/Common lines to your block diagram, this should help highlight any problems, including any 0V copper tracking on the modules
E
sirch2
Joined Jan 21, 2013
1,079
Here's a revised block diagram with the -ve rail shown, as I mentioned the Inverter isolates its input and output
38,938
Basically it's floating so its common-mode voltage would be determined by any leakage currents between the input and output of the inverter.
ericgibbs
Joined Jan 29, 2010
21,642
hi sirch,
If I am reading your circuit correctly, when C1 is 0V and C2 is 168Vdc, P1/A0 analog input pin will be a -Vin wrt to GND pin on the ADS1115, if the Soil/Earthing electrodes are in the alignment show in your diagram???
E
sirch2
Joined Jan 21, 2013
1,079
Well spotted, that's an error with the diagram. There is actually a change over relay for both current and voltage to average out self potential so they do swap but the A0 would be above ground
ericgibbs
Joined Jan 29, 2010
21,642
hi sirch,
I assume you have voltage overload protection circuit on the ADC inputs, to cover an event where the Earth resistance between A0 and Gnd, probes is very high.?
E
I would not ever "assume that the inputs to any package or system are isolated" UNLESS that claim is specificly stated, and qualified, with some voltage limit. Most isolation schemes do have a voltage limit, and, since providing isolation adds cost, that limit is usually clearly stated.
Earth resistivity measurement schemes have been around for many years! So there is a fair amount of published scheme designs around.
