Does polarity matter for a 12VDC relay?
Johnnyb60
Joined Sep 6, 2013
36
I bought a 12VDC/10A DPDT Plug-in Relay from RadioShack, but all I got was the socket so far. I want to start wiring for it now because I can just plug in the relay later when it gets here.
The problem is that I don’t know which of the coil terminals 7 or 8 is positive or does that even mater?
Not sure if the polarity would change the direction of the relay coil.
30,771
Some relays have a BEMF diode and/or a signal LED, if yours has neither then it should not matter, IF they are fitted then polarity matters..
If no BEMF diode fitted, one should be wired across the coil terminals and then the correct polarity should be observed, +ve to cathode.
Johnnyb60
Joined Sep 6, 2013
36
Well I don’t believe there is a BEMF diode in the Radio Shack relay, but I’m actually soldering a Bridge Rectifiers to the coil input because I have 12VAC supply and I can’t find a small AC relay to use.
Johnnyb60
Joined Sep 6, 2013
36
You know, now that I think about this particular relay I should have known this because it’s only an electro magnet pulling the contacts down. For some reason I was thinking if the poles were reversed the contacts would want to move away, but in this case the contacts aren’t magnetic. :oops:
snav
Joined Aug 1, 2011
115
The armature is magnetic but not a magnet so polarity is not important.
