Does Multi channel voltage inverters exist ?
ashokraj
Joined Feb 1, 2018
151
I am working with LM27761, It is a regulated, switched- capacitor voltage inverter. Currently I am converting +5V to -3.3V, I am wondering does an IC exist to convert +5 to two inverted voltages for example -3.3V and -2.5V.
I have noticed in signal amplifiers IC's that they will have a single channel, dual, quad channel outputs. Similarly, Does Dual channel voltage inverters exist ? especially from texas instrument.
I have searched in TI portal, Couldnt find any!
Apart from multi channel voltage inverters, do we have any IC's that can split the rail voltage into two rails ?
Datasheet of LM27761
