Does anyone recognize this surface mount component???
Pane77
Joined May 25, 2014
13
Hi there,
Can anyone tell me what this component might be? It's listed on the PCB as "U", which is INTEGRATED CIRCUIT but the actual marking on the component reads "PMMQ". Seems the "PM" is the same on this component if it's found on another board but the last 2 letters seem to change. It's also in line with the main microprocessor on the board. I've attached a picture and thanks in advance!
22,094
It is likely to be a transistor in a SOT23 package. The reference designator is U5 which normally indicates an IC (integrated circuit). AFAIK there are very few, if any, 3 terminal integrated circuits. Integrated circuits would be in a SOT23-5 package with 5 pins. The part obviously took a hit and I figure you have zero chance of affecting a repair by speculating on a replacement part without some information on the original design.
There are some cross reference tables which might help you cross PMMQ to an actual part.
I've looked at several and can't find a match.
jpanhalt
Joined Jan 18, 2008
11,087
One of the common non-transistor, 3-terminal devices is a voltage regulator. However, from the little portion of the pcb that you show, that does not seem like a likely possibility.
John
22,094
John
True enough except don't voltage regulators usually come in a SOT223 with a wide tab?
Like this:
http://www.ti.com/lit/ds/symlink/lm340-n.pdf
The proximity of X1, which looks like a ceramic resonator, suggests that a microprocessor might be nearby.
KL7AJ
Joined Nov 4, 2008
2,229
Hi there,
It's a highly toasted transistor
22,094
So even if the toasted component was replaced there is little to no guarantee that a similar fate would not befall the replacement. My vote -- the board is toast.
Pane77
Joined May 25, 2014
13
Thank you, thank you, thank you very much for the reply. It seems to be proprietary but I do appreciate all the help I can get. So even though it does not have a "Q" for transistor on the board, you're saying that it just might be a transistor? That helps. I will look into that. Thank you!
Pane77
Joined May 25, 2014
13
The component is fine, it was probably a soldering gun that hurt it. The component, if figured out, would lead to the repair of many boards that have this component go bad. The board sells for $700 to $1200 used. It's imperative that we find out what it is. Thanks...
22,094
Incidentally the reason for my belief is that an IC would normally have a Vcc pin and a GND pin. That leaves only one pin for I/O on a three pin device. For those conditions I cannot imagine a useful device. A voltage regulator in such a small package is possible but unlikely. It would have a big tab for a heat sink like the datasheet for the 340 series
In addition to a transistor it might be a dual diode with a common cathode or common anode.
Pane77
Joined May 25, 2014
13
I can also add that, without it on there, nothing, the entire appliance, does not work. Also, with it on the board, the ASA signature analysis is as follows in the picture. Basically, diode, diode. Which is normal for any IC so that doesn't help us much but here is a picture anyway.
Brevor
Joined Apr 9, 2011
297
It may be a "brownout detector" IC for the microcontroller.
I think the proper name is something like "reset controller" or something similar. See what pin on the microcontroller the unknown IC connects to and what it's function is.
alfacliff
Joined Dec 13, 2013
2,458
if it is testing like two diodes, it just might be a transistor.
or two diodes, there are smt packs that size with two diodes.
Pane77
Joined May 25, 2014
13
