Do I have a gremlin in the brain or a short in the circuit?
Mischief Maker
Joined Nov 16, 2017
5
My generator is starting of its own volition. Although I admire its enthusiasm the noise is sometimes unwanted.
I have taken the lid off and everything looks fine. I have checked the remote switches and they also look fine. How can I test whether this is a software problem with the control unit (DDC in this case) or a short elsewhere?
I have attached the wiring diagram for the generator. Any help or advice would be welcome.
Thanks in advance.
Alec_t
Joined Sep 17, 2013
15,171
Welcome to AAC!
If the remote is disconnected, does the problem still occur?
Is the generator exposed to damp conditions?
Mischief Maker
Joined Nov 16, 2017
5
Thank you Alec_t
There is a remote and when not connected the problem (so far) seems to not continue. Thanks for answering my question!
This does indeed encounter damp conditions as it is on a boat.
Next question will be how to reprogram the remote
Mischief Maker
Joined Nov 16, 2017
5
I have checked both sides of the cable and the connectors and both are clean without flaws. I guess this is a software problem in the remote but I struggle to see how it has just occurred now after many years of faultless service.
Alec_t
Joined Sep 17, 2013
15,171
If the remote contains any electrolytic capacitors they are likely candidates for the source of the problem, since they tend to suffer from increased ESR and loss of capacitance as they age.
It's also possible that the pcb in the remote has absorbed moisture enough for the insulation between tracks to be compromised.
gerty
Joined Aug 30, 2007
1,305
Another thing to look for since it's on the water is corrosion, especially if it's salt water. Is there perhaps a remote start connected to a bilge pump water level switch?
Mischief Maker
Joined Nov 16, 2017
5
Thanks for your enlightening input but after some further investigation the problem deepens.
The boat has two methods for AC current input. One for when the generator is running and one for when the boat is plugged into "shore" power. As you will see on the attached drawing there is a switch which differentiates between the two.
It appears that the the generator will only switch on and off by itself when the boat is plugged into shore power.
Baffling!
Alec_t
Joined Sep 17, 2013
15,171
Can you post a clearer pic of the section you've highlighted?
Is it possible that shore power gets back into the generator via the change-over switch and runs the alternator as a motor?
Alec_t
Joined Sep 17, 2013
15,171
Is that 'PC link' the remote control connection'? Perhaps interference on the shore power supply is getting through to it?
Is the problem a recent one? If so, can you identify any recent change in the boat's wiring etc ?
AllanGH
Joined Oct 1, 2013
19
Do yourself a favor....get some long cable that you can hook up to DMM leads, and check to see if you have a solid Earth connection at both ends of the ship to shore connection. IN other words, check to see if you can measure voltage between the electrical reference/safety Earth wiring on the boat and the Earthing connection at the shore mains tap. If you have anything over a couple tenths of a volt between the two, you may have found your problem.
