DIY Power Supply
ramram01
Joined Sep 11, 2020
5
Hi Guys,
I am a beginner. Can you help me, how to make a DIY Power Supply? I have a 12v AC adapter, I want to make it into a variable DC power supply from 0-12v. How much ohms of Potentiometer I need to make it? and also using a digital voltmeter to read how much is the variable output voltage.
AlbertHall
Joined Jun 4, 2014
12,625
First you will need a bridge rectifier and a smoothing capacitor to convert the AC input to a smooth(ish) DC voltage. That voltage will be around 15V which leaves 3V for the regulator overhead which is do-able.
Then you will need an adjustable regulator of some sort - you can't just use a pot.
There are some simple regulators which will adjust down to 1.2V. If you insist on it going down to zero volts it gets more complicated.
How much current can your AC adaptor supply?
ramram01
Joined Sep 11, 2020
5
It can supply 3 Amps. I am sorry, I mean I have a 12v dc adapter, my bad :)
AlbertHall
Joined Jun 4, 2014
12,625
OK, a regulator needs some voltage to work with so you can't get 12V out from 12V in unless you use a switch mode method which is a lot more complicated than the @bertus method in post #4.
ramram01
Joined Sep 11, 2020
5
If the adapter is 12 Volts DC, you can go from 1.2 to 9 volts using a LM317 for 1 Amp or LM338 for more amps.
With a LT1085 , you can get upto 11 volts on the output.
Bertus
yes, that's why I ask questions, to overcome stupidity hahaha. But Thank you very much. Much appreciated.
