Display Control Unit DCU for PFEIFFER vacuum Protocol devices using the PIC1847Q84
A replacement (inhouse) controller for the DCU that's expensive, rare and are a pain to repair when bricked by high voltage transients.
https://mmrc.caltech.edu/Vacuum/Pfeiffer Turbo/DCU Operatioins.pdf
Blown RS485 driver and logic regulator chips on the OEM board with a: https://www.nxp.com/products/68HC11E1 controller.
Adapting the FM80 interface board from another project for this one. It's only using the MODBUS port for pumping control.
DCU to TC 750 pump controller RS485 serial data.
https://www.ajvs.com/library/Pfeiffer_Vacuum_TPH_2101_P_PC_Manual.pdf
Q84 controller RS485 commands and responses. The Q84 RS485 driver (https://www.analog.com/media/en/technical-documentation/data-sheets/ADM3095E.pdf) is close to 4V signals vs the less that 3V signals from the OEM devices.
https://mmrc.caltech.edu/Vacuum/Pfeiffer Turbo/Pfeiffer Interface RS@32.pdf
Diagnostic mode on the Q84 display using the old Q84 controller board for testing and development.
Not using much of the boards total capability for this project.
Basic raw data monitor functions are done. Pump controller ID and Sw version, motor drive frequency, DC link voltage, Motor current and acceleration readouts.
Controller name request message and reply.
A simple FSM command sequencer and parser
C:
 * various PVP read-only messages
P_data P_read = {
    .addr2 = '0',
    .addr1 = '0',
    .addr0 = '1',
    .action1 = '0',
    .action0 = '0',
    .para2 = '3',
    .para1 = '0',
    .para0 = '9',
    .dl1 = '0',
    .dl0 = '2',
    .data1 = '=',
    .data0 = '?',
    .chk2 = '0',
    .chk1 = '0',
    .chk0 = '0',
    .cr = 13, // EOF CR
// 309 Act rotspd Actual rotation speed TMP in Hz 0-2000
 * PVP position set/read messages
P_data_r P_action = {
    .addr2 = '0',
    .addr1 = '0',
    .addr0 = '1',
    .action1 = '1',
    .action0 = '0',
    .para2 = '0',
    .para1 = '2',
    .para0 = '3',
    .dl1 = '0',
    .dl0 = '6',
    .data[5] = '1',
    .data[4] = '1',
    .data[3] = '1',
    .data[2] = '1',
    .data[1] = '1',
    .data[0] = '1',
    .chk2 = '0',
    .chk1 = '0',
    .chk0 = '0',
    .cr = 13, // EOF CR
// 023 Motor TMP  Motor Turbopump ON/OFF OFF ON ON(*) R/W 0
 * Simple MODBUS master state machine for soft DCU
 * this needs to run in the main programming loop
 * to handle RS485 serial I/O exchanges
int8_t master_controller_work_dcu(C_data * client)
    static uint32_t spacing = 0;
    if (spacing++ <SPACING && !M.rx) {
        return T_spacing;
    spacing = 0;
    client->trace = T_begin;
    switch (client->cstate) {
    case CLEAR:
        client->trace = T_clear;
        clear_2hz();
        clear_500ahz();
        client->cstate = INIT;
        client->modbus_command = client->mcmd++; // sequence modbus commands to client
        if (client->mcmd > G_LAST) {
            client->mcmd = G_ID;
         * command specific tx buffer setup
        switch (client->modbus_command) {
        case G_CONFIG: // read code request
            client->trace = T_config;
            client->req_length = modbus_dcu_send_msg((void*) cc_buffer_tx, (const void *) &P_read_N, sizeof(P_read_N));
            break;
        case G_DATA1: // read code request
            client->trace = T_data;
            client->req_length = modbus_dcu_send_msg((void*) cc_buffer_tx, (const void *) &P_read_I, sizeof(P_read_I));
            break;
        case G_DATA2: // read code request
            client->req_length = modbus_dcu_send_msg((void*) cc_buffer_tx, (const void *) &P_read_A, sizeof(P_read_A));
            break;
        case G_LINK: // read code request
            client->trace = T_link;
            client->req_length = modbus_dcu_send_msg((void*) cc_buffer_tx, (const void *) &P_read_L, sizeof(P_read_L));
            break;
        case G_VERSION: // read code request
            client->trace = T_version;
            client->req_length = modbus_dcu_send_msg((void*) cc_buffer_tx, (const void *) &P_read_V, sizeof(P_read_V));
            break;
        case G_LAST: // end of command sequences
            client->cstate = CLEAR;
            client->mcmd = G_ID; // what do we run next
            break;
        case G_ID: // operating mode request
            client->trace = T_id;
        default:
            client->req_length = modbus_dcu_send_msg((void*) cc_buffer_tx, (const void *) &P_read, sizeof(P_read));
            break;
        break;
    case INIT:
        client->trace = T_init;
         * MODBUS master query speed
        if (get_500ahz(false) >= CDELAY) {
            half_dup_tx(false); // no delays here
            M.recv_count = 0;
            client->cstate = SEND;
            clear_500hz();
            client->trace = T_init_d;
        break;
    case SEND:
        client->trace = T_send;
        if (get_500hz(false) >= TEDELAY) {
            for (uint8_t i = 0; i < client->req_length; i++) {
                Swrite(cc_buffer_tx[i]);
            client->cstate = RECV;
            clear_500hz(); // state machine execute background timer clear
            client->trace = T_send_d;
            M.sends++;
            M.rx = false;
            if (serial_trmt()) { // check for serial UART transmit shift register and buffer empty
                clear_500hz(); // clear timer until buffer empty
            delay_ms(TDELAY + client->req_length);
            DERE_SetLow(); // enable modbus receiver
        break;
    case RECV:
        client->trace = T_recv;
        if (get_500hz(false) >= TEDELAY) { // state machine execute timer test
            client->trace = T_recv_r;
            half_dup_rx(false); // no delays here
             * check received response data for size and format for each command sent
            case G_VERSION: //
                modbus_read_dcu_check(client, &client->version_ok, sizeof(P_action));
                break;
            case G_LINK: //
                break;
            case G_CONFIG: //
                modbus_read_dcu_check(client, &client->config_ok, sizeof(P_action));
                break;
            case G_DATA1: //
                modbus_read_dcu_check(client, &client->data_ok, sizeof(P_action));
                break;
            case G_DATA2: //
                break;
            case G_ID: // check for client module type
            default:
                modbus_read_dcu_check(client, &client->id_ok, sizeof(P_action));
                break;
        break;
    default:
        break;
    return client->trace;
Have my V1.0 prototype boards from JLC.
A redesign that eliminated the FM80 interface and replaced that with RJ45 connections to power and RS485.
Testing with a good and bad TC750 Turbo Pump Controller. On power-up the bad motor controller runs OK for a few minutes and then locks up.
Motor controller link power-up and DCU boot (the large HEX number duning the boot sequence is the PIC chip unique ID) with communications startup log messages.
https://microchip.my.site.com/s/article/Microchip-Unique-Identifer--MUI--on-PIC18F--PIC16F-devices
C:
* Device Information Area (DIA) Table
#define DIA_MUI                                             0x2C0000
#define DIA_MUI0                                            0x2C0000
#define DIA_MUI1                                            0x2C0002
#define DIA_MUI2                                            0x2C0004
#define DIA_MUI3                                            0x2C0006
#define DIA_MUI4                                            0x2C0008
#define DIA_MUI5                                            0x2C000A
#define DIA_MUI6                                            0x2C000C
#define DIA_MUI7                                            0x2C000E
  * read and store the CPU_ID for PCB tracing
    B.mui[i] = DeviceID_Read(DIA_MUI + (i * 2)); // Read CPU ID from memory and store in array
device_id_data_t DeviceID_Read(device_id_address_t address)
    device_id_data_t deviceID;
    //Save the table pointer
    uint32_t tablePointer = ((uint32_t) TBLPTRU << 16) | ((uint32_t) TBLPTRH << 8) | ((uint32_t) TBLPTRL);
    //Load table pointer with Device ID address
    TBLPTRU = (uint8_t) (address >> 16);
    TBLPTRH = (uint8_t) (address >> 8);
    TBLPTRL = (uint8_t) address;
    //Execute table read and increment table pointer
    asm("TBLRD*+");
    deviceID = (device_id_data_t) TABLAT;
    asm("TBLRD*");
    deviceID |= (device_id_data_t) (TABLAT << 8);
    //Restore the table pointer
    TBLPTRU = (uint8_t) (tablePointer >> 16);
    TBLPTRH = (uint8_t) (tablePointer >> 8);
    TBLPTRL = (uint8_t) tablePointer;
    return deviceID;
Vacuum turbo pump running at set speed of 525 Hz three-phase drive. RS485 decoded on the scope and on the Q84 DCU display.
The small pump is between the V63 and V60 vacuum manifold.
Connected to smaller turbo pump @1000Hz drive. Low load pumping at 1e-6 torr vacuum.
Last control and monitor test before a production PCB spin. The Q84 will piggy-back the display and the RS485 termination bias was reworked a bit to increase the inactive bus voltage to 200 mV.
Enclosure. Download a generic 4X20 LCD panel STL file. Needs work. ;)
Modify that after measurements.
Hacked the back side to make box measurements for modifications when the new boards arrive.
Have my production boards from OSHpark.
JLC with plating and upgraded FR4 (extra cost) is not too bad for the price.
Same manufacturing file on both.
JLC
OSH
Production spin of board and case. Redesigned the PCB to eliminate connectors and for a out the back RJ45 connector.
Mounted on headers pins from the LCD.
CF 3D printed case. With a glued plastic spacer to support the bottom of the board.
