Is a micro controller an option? Have you ever programmed one?Hi Folks,
Is there any way to scale a 4-20ma output into a 0-100 on a display? Does anyone know how to easily do this with electronic components rather than me using an arduino or other plc?
Thanks for the help.
Cheers
Yes a Micro-controller can be an option as a last resort. I have programmed loads. Just finished a degree in Mechatronic engineering so thats basically all i did for the past 4 years ha.Is a micro controller an option? Have you ever programmed one?
OK Your call. A friend of mine works with all kind of machinery / instruments used in that environment. Never heard such a terminant opinion from him.Yes a Micro-controller can be an option as a last resort. I have programmed loads. Just finished a degree in Mechatronic engineering so thats basically all i did for the past 4 years ha.
I dont want to use a microcontroller if possbile for the reason that its working in an agricultural environment and from my experience microcontrollers work perfect on your desk but not bouncing up and down a field.
by Aaron Carman
by Duane Benson
by Robert Keim
