Dimming an LED
Saiteja chinthalapati
Joined Oct 25, 2018
97
Hello everyone,
I developed a project to dim an led from 0-24v by using a controller and it is working fine. Now i am looking for a circuit without controller. could someone suggest something on this.
My input voltage to board is 24V and LED will also work 24V i want to DIM LED from 0 to 24V without controller
danadak
Joined Mar 10, 2018
4,057
So you want to dim, but you don't want circuit that implements dimming.
A Venetian blind, a pull window shade..... (being a smartass)
How do you want to actually tell LED to dim, a pot, a sensor.....? But no circuits ?
Regards, Dana.
Joined Oct 25, 2018
97
Regards, Dana.
I want to use pot for dimming and mosfet or relay to turnoff the led. I required smooth dimming from 0 to 24v
ElectricSpidey
Joined Dec 2, 2017
3,359
If you are not concerned about power loss, a simple transistor follower circuit will do the job for the dimming, and a simple switch can turn on and off, or operate a relay.
A power rheostat would also work.
After that things get a little more involved…
wayneh
Joined Sep 9, 2010
18,164
... i want to DIM LED from 0 to 24V without controller
Can you explain what you mean by this? If you are dimming the LEDs, by definition you are using a "controller".
I think you mean you want to eliminate an expensive? or clumsy? device you have used successfully and replace it with something cheap? or small? or ... what? What are you really trying to accomplish?
Most people would recommend a PWM-based controller for smooth dimming of LEDs. It's the state-of-the-art solution and many commercially available dimmers exist. They are not expensive and are hard to beat. What improvement are you looking for?
Joined Oct 25, 2018
97
i am dimming the LED by using Arduino controller now i want to do by using Potentiometer & without controller. LED input voltage is 24V
ericgibbs
Joined Jan 29, 2010
21,571
hi Sc,
A 2N2222 transistor cannot control a 2Amp Collector current.
The circuit in post #8, was posted as just an example of a dimmer, it will require a higher power output transistor or MOSFET.
E
wayneh
Joined Sep 9, 2010
18,164
Whose suggestions are you referring to? What did you try that didn’t work? What was the result?
The circuit in #8 is valid but requires a couple minor changes for driving a 24V, 2A load.
