Dim LED
biferi
Joined Apr 14, 2017
529
I wanted to know if anybody can help me find a not very Bright LED on amazon?
I know I can Buy Fairy Lights but they are Bulbs not LEDs and they burn out fast.
I only need say 6. of them the kind with the 2. Legs on them for a project I am doing.
wayneh
Joined Sep 9, 2010
18,104
LED brightness is nearly proportional to the current driven through it, up to the maximum current the LED is rated for. You can dim an LED by placing a resistor in series or by pulse-width modulation PWM
Jon Chandler
Joined Jun 12, 2008
1,595
One thing to look for:
Diffused LEDs provide diffused, wide area light. Looking at them directly you see more of a glow.
Non-diffused LEDs provide a narrow cone of light. Looking at them directly can be blinding. Typically, this type of LED will project a spot of maybe 4" on the wall from 4' away.
BobTPH
Joined Jun 5, 2013
11,515
That would be an extremely narrow angle, I calculate 5°.
Jon Chandler
Joined Jun 12, 2008
1,595
The point was that they are a tight beam that can be blinding. The poster asked for dim LEDs and non-diffused LEDs aren't going to provide that. It matters not if the angle is 5°, 15° or 27.3°. Non-diffused LEDs are not pleasant to look at directly.
biferi
Joined Apr 14, 2017
529
I have a White 1,520 mcd LED.
It needs 20 mA at 3.2 V. to Run.
I have a 6. Volt Battery Pack and yes I know how to use Ohms Law to find the Resistor I need to run it/
So are you telling me if I use a High Resistor to limit more Current to my LED the LED will be Dimmer?
SamR
Joined Mar 19, 2019
5,487
20mA is "typically" full current. Reducing current to the LEDs from 20mA will dim them. Then there are serial/parallel voltage drops across the LEDs to consider as well.
27,507
First, as has already been mentioned, the brightness of an LED is controlled by the current, which is affected by the applied voltage. That relationship applies to ALL LEDs that do not contain additional electronic circuitry.
IN ADDITION, the bright and tightly focused beam LEDs can often be changed to provide a much wider beam by simply using fairly fine sandpaper to roughen the lens surface.
Finally, in most cases the 20 milliamp current mentioned IS THE MAXIMUM CURRENT FOR THE SPECIFIED LIFETIME of that device!!
It is not by any stretch the specified operating value!!
I have driven those 20mA LEDs to quite adequate brightness directly from 5 volt CMOS gates, which deliver a bit over 3 volts in that application.
