Dim bulb current limiter design
briesmith
Joined Mar 20, 2021
5
I have built a dim bulb current limiter in the usual configuration. (See attached PDF).
The earth wire (ground or CPC) runs from the earth pole on the mains switch via the earth pole on the lamp socket and onto the earth tag on the output socket (outlet).
The neutral wire runs from the neutral pole on the mains switch directly to the neutral pole on the output socket.
The live wire runs from the live pole on the mains switch through the neutral and live poles on the lamp holder and onto the live tag on the output socket.
The bypass live wire runs from the neutral pole on the lamp holder through a simple on/off switch and back to the live pole on the lamp holder.
I want to use a 220VAC neon indicator to show when the bypass has been enabled (ie circuit isn't being limited) but find that when I put a lamp (bulb) into the system, the neon lights up even though the bypass is switched off.
Where should I connect the two poles of the neon indicator lamp to stop this happening? (Can I stop it happening?)
briesmith
Joined Mar 20, 2021
5
Thanks for replying Bob, appreciate you taking the time.
Sorry, but I don't understand how the switch type you recommend would be wired.
BobTPH
Joined Jun 5, 2013
11,655
The DPDT has two separate switches that can switch a center contact to either the left or right contact.
Use the left and center of one switch to bypass the bulb.
Use the left and center of the other as a power switch for the neon bulb.
Now the neon light is on whenever the bulb is bypassed.
If you can find a DPST that would work as well, but I think DPDT are actually more common.
