Differential amplifier design
Alexx98
Joined Nov 5, 2017
30
Your PNPs are in the circuit backwards and there are missing connections on the lines labeled as outputs.
Thank you! I changed the output part but the only pnp model that I find is this one. The desired pnp model is 2N2907, I can't fix this. I'm not familiar with Spice
ebp
Joined Feb 8, 2018
2,332
You simply need to flip the symbol top-to-bottom. I don't know how you do this in LTspice since I don't use it, but there are probably mirror and rotate operations e.g. rotate 90 degrees twice then mirror
edit: there may be a mirror vertically operation which does what is required in one step
Alexx98
Joined Nov 5, 2017
30
Yes, thank you now it is all done I think :)
ebp
Joined Feb 8, 2018
2,332
You should/must (?) name the two outputs differently. If they have the same name the simulator may consider them to be connected.
.tran 4mS (assuming that is correct syntax, which again I don't know) should be
.tran 4ms - lower case s for seconds, upper case for Siemens (unit of transconductance)
Alexx98
Joined Nov 5, 2017
30
The given circuit names them as the same Vout. But I'm changing it in LTspice now. Thank you again.
38,927
The original circuit names the differential output from the two outputs as Vout.
Spice connects all nodes with the same name together, so you need to label the two inputs and two outputs with different names.
I've sometimes been puzzled by strange simulated circuit behavior when I've inadvertently given two different nodes the same name and Spice dutifully connects them together. :rolleyes:
