Different between the log circuits
ali.
Joined Feb 23, 2012
4
Hello Everyone,
I’m looking for some help:
What is the different between the log circuits using only diode with current source or using pomp with diode?
38,755
The op amp converts input voltage to a current source of Vin/R through the diode and provides a low output impedance to drive a load. Otherwise the voltage versus diode current will be the same.
ali.
Joined Feb 23, 2012
4
Thank crutschow for your quick reply so if the output of the log circuit connected to completer op amp there is no different between the 2 log circuits :)
38,755
It's the same if you understand that the op amp circuit has a voltage input and the diode circuit has a current input. So the inputs are different but the outputs are the same (for the same equivalent diode current).
