Great advice. I totally forgot that when I grounded pin 2 of U2 in the console board. I'm trying to go carefully, but things can still be forgotten. While I did work very effectively as a tech, it's been a long time.thatoneguy said:When you are going to put an input at 0V, use a resistor to test first, something around 500 ohms
No it's U1, its outputs, pins 4 and 6. I missed that label in the schematic, but it's updated now.R!f@@ said:That is U6 CE shorted..right?
Idle: 0.02VDCR!f@@ said:Looking at the schema, remove R49. Or u can remove one pin of R.
Connect the board and power up the tread.
Connect meter negative to C4 negative, connect the red to pin 5 of console board.
Hit run and check the voltage change from Idle to Run.
Tread does not run.R!f@@ said:keep the resistor removed ... power down and bridge CE of Q5 ( schema). This action should turn on the opto U6.
Now check if the tread runs.
Negative of C36 is ground (pin 2) of U4R!f@@ said:Ground terminal this time shud be the negative of C36 which is at the output of 15V reg, U4.
Pin 3: 14.6VR!f@@ said:Post the voltage level at pin 3 & 1 of U2 (78L12)
Pin 4: 5.8VR!f@@ said:Post the voltage level of pin 4 & 9 at mini board connector
Glowing steadily at approx. 20% brightness.R!f@@ said:Post back what you observe from the LED.
Best I can do!R!f@@ said:We need to see the mini board
