Hi guys!
I am trying to make a DHT22 sensor interface using a PIC16F887. I compiled the code below and it works, but when I simulated it in Proteus, there is a problem with the "Check_Response" function. The LCD displays the message "No response from the sensor".
I am using the mikroC PRO for PIC compiler and Proteus 8 Professional for simulations.
I attach the schema used in Proteus.
DHT22 Interface:
// LCD module connections
sbit LCD_RS at RD0_bit;
sbit LCD_EN at RD1_bit;
sbit LCD_D4 at RD2_bit;
sbit LCD_D5 at RD3_bit;
sbit LCD_D6 at RD4_bit;
sbit LCD_D7 at RD5_bit;
sbit LCD_RS_Direction at TRISD0_bit;
sbit LCD_EN_Direction at TRISD1_bit;
sbit LCD_D4_Direction at TRISD2_bit;
sbit LCD_D5_Direction at TRISD3_bit;
sbit LCD_D6_Direction at TRISD4_bit;
sbit LCD_D7_Direction at TRISD5_bit;
// end LCD module connections
// DHT22 sensor connection (here sensor data pin is connected to pin RB0)
sbit DHT22_PIN at RB0_bit;
sbit DHT22_PIN_Direction at TRISB0_bit;
// End DHT11 sensor connection
char temperature[] = "Temp = 00.0 C ";
char humidity[] = "RH = 00.0 % ";
unsigned short T_byte1, T_byte2, RH_byte1, RH_byte2, CheckSum, checkBit ;
unsigned int Temp, RH;
void Start_Signal(void){
DHT22_PIN_Direction = 0; // Configure connection pin as output
DHT22_PIN = 0; // Connection pin output low
Delay_ms(25); // Wait 25 ms
DHT22_PIN = 1; // Connection pin output high
Delay_us(25); // Wait 25 us
DHT22_PIN_Direction = 1; // Configure connection pin as input
void Check_Response(void){
checkBit = 0;
Delay_us(40);
if(DHT22_Pin == 0){
Delay_us(80);
if(DHT22_Pin == 1){
checkBit = 1;
Delay_us(50);
char Read_Dht22(){
char i;
char dataVar;
for(i = 0; i < 8; i++){
while(!DHT22_Pin);
Delay_us(30);
if(DHT22_Pin == 0){
dataVar&= ~(1<<(7 - i)); //Clear bit (7-b)
}else{
dataVar|= (1 << (7 - i)); //Set bit (7-b)
while(DHT22_Pin);
} //Wait until PORTD.F0 goes LOW
return dataVar; //Read value
void main() {
//ANSELH = 0;
Lcd_Init(); //Lcd initialized
Lcd_Cmd(_LCD_CURSOR_OFF);
Lcd_Cmd(_LCD_CLEAR); //Clean display
while(1){
Delay_ms(800);
Start_Signal();
if(checkBit){
RH_Byte1 = Read_Dht22();
RH_Byte2 = Read_Dht22();
T_Byte1 = Read_Dht22();
T_Byte2 = Read_Dht22();
CheckSum = Read_Dht22();
if(CheckSum==((RH_Byte1+RH_Byte2+T_Byte1+T_Byte2)&&0xFF)){
RH = RH_Byte1;
RH = (RH << 8)|RH_Byte2;
Temp = T_Byte1;
Temp = (Temp << 8)|T_Byte2;
if(Temp > 0x8000){
temperature[6] = '-';
Temp = Temp & 0x7FFF;
}else{
temperature[6] = ' ';
temperature[7] = (Temp / 100)%10 + 48;
temperature[8] = (Temp / 10)%10 + 48;
temperature[7] = Temp / 10 + 48;
if(RH == 1000){
humidity[6] = 1 + 48;
}else{
humidity[6] = ' ';
humidity[7] = (RH / 100) % 10 + 48;
humidity[8] = (RH / 10) % 10 + 48;
humidity[10] = RH % 10 + 48;
temperature[11] = 223; //° Symbol
lcd_out(1, 1, temperature); //Display temperature
lcd_out(2, 1, humidity); //Display humidity
}else{
lcd_out(1, 1, "Checksum Error!");
}else{
Lcd_out(1, 3, "No response");
Lcd_out(2, 1, "from the sensor");
Delay_ms(1000);
