Determine length of side of right triangle for given angle?
spinnaker
Joined Oct 29, 2009
7,830
I have a solar panel mounted on a fence post. I need to adjust the panel angle throughout the year.
Instead of requiring a protractor, I would like to make a graduated scale marked with the months. To make the job easier, I would like to measure one of the sides of the triangle to set the required angle.
Example below. How would I calculate the length of side B for 26°?
35,031
I believe, in this application A will be changing.
You want to use the fixed length C.
sin(angle) = B/C
where the angle is in radians, i.e.
angle in radians = (angle in degrees) x 3.14159 / 180
Wendy
Joined Mar 24, 2008
23,806
Are you familiar with the law of sines? It is one of those formula I hang on to, because it tends to fill in for so many problems.
A / Sine Angle A = B / Sine Angle B = C / Sine Angle C
The Angles are opposite the sides. I'll stick in an illustration when I have more time.
... I would like to measure one of the sides of the triangle to set the required angle.
you can't.
you have to have the measure of at least one side of the triangle in order to use any of the trigonometric functions.
assuming side C is the solar panel, and therefore of constant length, any change made to the angle formed by sides A and C will change the lengths of sides A and B (remember C doesn't change). If the measure of the angle increases, B must get longer while A gets shorter. If the measure of the angle decreases, B will get shorter while A gets longer.
if C is of constant length, then:
C*sin (26 degrees) = B
and
C*cos (26 degrees) = A
