Designing a voltage regulator for 1000W bulb - 18 AMP circuit
randomphd
Joined Aug 15, 2023
Hello
I am a phd student who wants to regulate the voltage of a 1000W bulb to regulate its light intensity. I do not have a background in electrical. What options should I consider for accuracy as well as durability of setup?
LowQCab
Joined Nov 6, 2012
5,102
What is the end-purpose of the Bulb ?
What is the purpose of regulating the Power to the Bulb ?
Will the Power-Regulation be manual, or automatic, or both ?
Ian0
Joined Aug 7, 2020
13,306
If it is just for experimental purposes, over a fairly short time frame, then use a variac. The labs will have lots of them.
tautech
Joined Oct 8, 2019
507
Hello
You haven't disclosed if this is AC or DC and if AC, phase control is the most common method.
Power Triacs or dual SCR's can be used with appropriate ratings, heatsinked of course.
