Designing a simple Treadmill Controller based on Power Track Pro 97370
nestbulala
Joined Dec 12, 2015
111
My treadmill broke down and I want to design a controller and LCD display using PIC16F88. I started on the power for the DC Motor that is being controlled by a mosfet with the current sense circuit in case it is overloaded. My concern is the current sense which I get from this forum is of a different ground potential from PIC. My question is, can it sense even if of different ground potential and what is the reference if you measure it? Please find the attached drawing for your reference.
Power Track Pro 97370 Treadmill Main Board.png Power Track Pro 97370 Treadmill Display Board.png
nestbulala
Joined Dec 12, 2015
111
Attached a picture of the board. Actually, the display board fails and i brought it to the supplier for testing the board. They swapped it to the running board and it was ok. But I misplaced the display board. I might have thrown it on the garbage. Now since I am learning on PIC programming why don't we give it a try. After some searching, I have come up with this circuit and with this forum of experts I have come for help. Any comments or suggestions would be highly appreciated. And I Thank You in advance for your help.
Power Track Pro 97370M Treadmill back PCB.jpg Power Track Pro 97370M Treadmill.jpg
nestbulala
Joined Dec 12, 2015
111
Simulated from LTSpice for the current sense for the board to trip the relay when it reached 12A. Any advice on this circuit Guys.
Alec_t
Joined Sep 17, 2013
15,156
In your post #3 circuit M1 would need to be an NMOS device.
By the way, posting your .asc files is generally helpful.
Alec_t
Joined Sep 17, 2013
15,156
I don't see why you need a FET at all if you just want to activate a relay when sensed current is >12A. What FET will you use? It will need a Vdsmax rating considerably higher than 380V. If Q1 will be used to drive the relay, don't forget the free-wheel diode across its coil.
nestbulala
Joined Dec 12, 2015
111
In the main board, Q1 is FET that will drive the DC Motor rated 190VDC. Q3 will drive the relay that will trip the supply when it reach 12A. This is the main board schematics.
