I believe this is a pretty basic question but I haven't found anything that entirely covers my question in the forum so here I go:
I'm prototyping a feature that requires obtaining the approximate ambient light measurement in lux with a phototransistor and I need some help interpreting the datasheet.
My circuit is a simple common collector configuration (please see the attached file).
I need to adjust the range in a way that it will saturate at 65000 - 70000 lux
I'm trying to make sense of the datasheet (images attached) to choose the value of my load resistor.
The datasheet says:
- ON State Collector current (typical) = 2 mA when Vce = 5V and the irradiance is 1mW/cm2
- Collector-emitter saturation voltage (typical) = 0.4V when Ic = 2mA and the irradiance is 1mW/cm2
I don't have a lux meter to verify or calibrate, so I need to extrapolate this information to my particular case:
- 3.3V supply
- Saturation at 65000-70000 lux
What confuses me is the fact that the irradiance vs collector current chart is relative and not absolute.
So my question is: how to proceed?
Here's my guess:
- Apparently, 1 mW/cm2 = 6830 lux at 555 nm
- If I understand correctly, the relative irradiance vs collector current chart in this case just means that the relationship between irradiance and current is linear.
- If at 5V, 6830 lux is 2 mA, then at 3.3V it is 0,132 mA (3.3V/5V = 0,66 factor)
- Therefore if we put 68300 lux into the sensor (6830 x 10) then the current would be 10 times as much (1.32 mA)
- If the saturation voltage is 0.4V when Vce=5V, then in my case it would be 0.264V (x0.66 factor again)
- Therefore my resistor should be ((3.3V-0.264V) / 1.32 mA) = 23K
- And the ADC voltage reading would linearly scale with the lux reading from roughly 0V (there is a small voltage produced by dark current) and 3.036V, and that would be roughly 22496.7 lux per volt.
- With a 3.3V-referenced 10-bit ADC, I would have about 3.2mV per count or 72 lux per count.
Is this correct or I'm misinterpreting the information or the workings of the phototransistor?
Thanks in advance!
The datasheet says:
- 3.3V supply
Here's my guess:
Thanks in advance!
