Designing 12v bldc ceiling fan
Status
Not open for further replies.
D_Naik
Joined Oct 17, 2023
12
Hello everyone,
We are designing a BLDC ceiling fan for that we have a 18 slots stator, 16 pole magnetic ring, enclosure, blades and other things for making 12v bldc ceiling fan. We already have the driver/ controller.
Where we can find the design and calculation for winding structure? Or any simulation software is available for free where we can test.
BobTPH
Joined Jun 5, 2013
11,647
It is hard to imagine how you could design the rotor and stator without understanding how it would be wound.
I don’t see how 16 poles works if you were planning on 3-phase.
Jerry-Hat-Trick
Joined Aug 31, 2022
847
Typically, a ceiling fan has a large diameter and rotates relatively slowly. For such a project I'd look at using a BLDC window winding motor, maybe even a windscreen wiper motor as they are relatively inexpensive to buy (made in large quantities) and they are robust and reliable. Designing and building a motor from scratch is not a trivial task and unless your planned volume is significant, it'll be far more costly.
D_Naik
Joined Oct 17, 2023
12
Hi, bobTPH
We are not designing the stator and rotor as I said above so it is fix we are finding winding calculation to work with 12v. It can be also done with trial and error by winding different turns but we don't want that.
D_Naik
Joined Oct 17, 2023
12
Hi, Jerry-Hat-Trick
We reverse engineered the 12v ceiling fan having 12 slots and 14 poles magnet it having 37 wound on each teeth. But it has different stator than ours.
Status
