Design of two stage amplifier
falade47
Joined Jan 24, 2017
178
Please i was asked to design a two stage amplifier with the following charaxteristics Av =4000, Zi=4.7kohm, Vcc=12v. .need help with this please..
BobTPH
Joined Jun 5, 2013
11,667
What are the constraints on the 2 stages? If they are unconstrained, use 2 op amps and it becomes pretty easy.
Bob
sghioto
Joined Dec 31, 2017
8,758
Wow a two stage transistor amp with a gain of 4000. Lets see, first stage with a gain of 40 followed by the second stage with a gain of 100 will work. Probably going to be a noisy SOG.
SG
falade47
Joined Jan 24, 2017
178
SG
Can you help out with a schematic..?..
dendad
Joined Feb 20, 2016
4,642
This sounds like homework.
You will get a lot more help if you post an attempt at the problem. Most of us are unwilling to do your work for you. You learn by doing, not by getting it done for you.
Have a go at it and post your efforts first. Then you may find some help.
And I note, you have at least doubled up on this post. One is sufficient.
bertus
Joined Apr 5, 2008
23,026
As said the 4000 times can be reached using an 40 and 100 times stage.
Also an 50 and 80 times stages might work.
Bertus
